Quick update, took the plunge and got stuck in today, have now removed left hand side and refitted the new bush. Hopefully get the right hand side done tomorrow.
This job is an absolute bitch, but like everyone said, the tough bit is getting the old one out. Town was spot on, the alloy core was still attached to the car, a local garage lent me their sets of bush removal tools and we were able to put together a primitive set up to pull the bush out 10mm then cut the bottom off and push the rest through. Took 2 of us all day but after getting the tools, about 2.5 hrs.
New one went in easily after really cleaning everything and using loads of Fairy Liquid to slide it in, used a trolley jack to push it in. This was done with the beam still on the car, working in tight spots as you can imagine.
Hopefully tomorrow will be easier now we've done one and also need to return the tools.
I have some pics but no time now so will add tomorrow night. Also i will let everyone know the name of the garage as they are so helpful. Top guys.
Thanks for everyone's advice, was really helpful in the end.
Jon
Rear beam bush damage - Replacing them.
mrjonchandler
Have put pics in the photo gallery thread.
Jon
Jon
TouringTash
clickie ?
come on fella need more than a pic or two how did it pan out?
318i Touring
mrjonchandler
We were trying to get it done quick so just didn't get the chance to take many more pics. Thought about what you said about the weather, we went outside to start sizing it up and before we knew it, we just started undoing the bolts and getting rust in the eyes!TouringTash wrote:clickie ?
I'll be honest....It wasn't that bad, but without the lend of a bush removal kit from this garage round the corner, it would have been a real bitch. Getting the old ones out was made easier, used a 3 foot scaffold pole ton the end of the socket wrench to gently ease the 22mm nuts undone, that helped.
I used a scissor jack, a piece of wood and a trolley jack to support and lower/lift the beam and diff.
We did one side at a time because i wanted one side complete before attempting the other, once the old bush was out and the hole cleaned, the new one pushed in with the trolley jack and loads of Fairy liquid.
Lining up the bush with a bar through the car was helpful as you guide in the top of the bush into the recess under the sill.
Are you gonna do yours then? The difference was very noticable when driving it after, i changed the top mounts too.
Hope you're well mate.
Jon
TouringTash
cheers for the heads up Jon.
I'll be doing mine at the end of Oct along with an engine swap (only an M20b20 but its lying around doing nothing), new suspension and brake overhaul and all the rear bushes not one for an easy time though I'll be kidnapping a grease monkey for two days to make sure it gets done. Cheating ?
YouBetYa, but with the lack of space in my garage I get wound up after 4 hrs and have to walk away, though managed 7 this eve, off for a bath now.
I'll get some before and after shots.
318i Touring
mrjonchandler
So what you doing with your engine!!!!!!!!!!!!!!!!TouringTash wrote:cheers for the heads up Jon.
See what i'm getting at?!
TouringTash
beeing thinking about that on the throne and is the motronic, loom, gearbox the same as my 318 on a 94 plate?
Let me know whats on the ECU (numbers, codes) and I'll look into it.
Might be easier to do a head swap with another 316.
318i Touring
mrjonchandler
Still trying to get the image of you on the throne out of my mind!TouringTash wrote:beeing thinking about that on the throne and is the motronic, loom, gearbox the same as my 318 on a 94 plate?
I actually know where one is (a 1.6 head). but is it any better than mine? Who knows, what should i pay for a head?
Jon
1.6 and 1.8 heads are the same, as are the loom and gearbox.
TouringTash
Cheers Brian I did wonder about that.
Jon I've spoken with my mech and he says its not worth changing to the m20b20 from my m40 so if you fancy a very cheap m20b20 I'll pull it out along with the box. Gonna stay with plan A for the m40 and see what I can get out of it. Less than 220 and I'll go back to boats.
318i Touring
TouringTash
bugger! Sorry Jon I should have asked my mech about a head
as he's trustworthy, honest and reliable. I know! all that from a mechanic
. Just waiting on the month of Sundays and after spotting a unicorn last week I'll have a full set.
I'll get you a price on monday. Can't be worth more than a bulls eye can it?
318i Touring
