325i low idle speed
sweep
Fri Jun 11, 2010 10:24 pm
John you can hold the compresion guage then.
StuBeeDoo
Sat Jun 12, 2010 11:49 am
Any news yet??
sweep
Sat Jun 12, 2010 1:41 pm
All compresions are just over 175 on the guage.all plugs were the same colour light brown slightly weak mixture.
murran
Sat Jun 12, 2010 6:15 pm
well that sounds fine.
sorry i wasnt able to come down, i got dragged to meadowhell insted.
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
sweep
Sat Jun 12, 2010 6:27 pm
A dodgy injector?
StuBeeDoo
Sat Jun 12, 2010 6:56 pm
Good news then. :D
If I were you, I'd be going over all that I did before the problem started with a fine-tooth comb before I start trying to work out what else could be causing it.
sweep
Sat Jun 12, 2010 8:42 pm
Im thinking now have i disturbed a injector?but all the plugs are the same colour.maybe get new ones.
sweep
Sun Jun 13, 2010 5:02 pm
Bump
b17
Sun Jun 13, 2010 9:40 pm
why not get your injectors cleaned? It will eliminate one possiblity
sweep
Wed Jun 16, 2010 6:44 pm
Injectors sent fot refurbing today.
sweep
Mon Jun 21, 2010 7:51 pm
Just fitted my refurbed injectors.car is much smoother but it is still ticking over low :(
sweep
Wed Jun 23, 2010 4:49 pm
Any more ideas on this one folks.. as well as the low idle speed when im rolling up to junctions the revs drop below the tickover speed and come back up !Could this be anything to do with the alternator voltage regulator?is there a idle control moduel on these?
Wed Jun 23, 2010 7:08 pm
strange this.. :( even if 1 pot was down, the tickover shouldn't be so low,
have you tried another crank sensor ? easy to do a quick test Pete, leave the old sensor wiring in place coz it's fiddly to get it back right
bolt the new sensor in, route the wire over the dizzy, got to be worth a try, just a case of eliminating stuff
sweep
Wed Jun 23, 2010 7:49 pm
I will give it a go steve
clipper
Wed Jun 23, 2010 10:15 pm
Don't wish to sound stupid (but I will....) but why is this a problem ?
My 325i ticks over at about 600 rpm but it doesn't give me any trouble at all, except very ocasionally it will stall with the steering at full lock and the air con on.
I'd never considered it to be a major worry :o:
sweep
Thu Jun 24, 2010 6:12 pm
I have tried a crank sensor today and its the same,when its running and i disconect the tps wiring plug the engine does not alter is this right?
town325i
Thu Jun 24, 2010 7:31 pm
No it should start to run dodgy as the ecu doesnt no where the butter fly is
sweep
Thu Jun 24, 2010 8:48 pm
Mine doesnt alter anything,
TouringMatt
Thu Jun 24, 2010 9:02 pm
Mate i've been in the exact same situ with mine for the past 5 years, never got to the bottom of it.
Recently changed all gaskets, brake servo hoses etc to eliminate air leaks, traced connections back to the ECU and checked voltages and readings and i have pretty much to same results as you.
Car idles at around 600rpm, only a touch higher from cold and never feels 100% right, like you say, another 100rpm would help smooth things out.
Have you ever checked the voltage at the idle control valve? Mine's never tied up with the figures in manuals. Its done my head in in the past trying to solve it, it usually ends up in me winding the throttle cable in a bit to cheat the idle speed, wrong i know but stalling out at junctions aint fun!
Matt
sweep
Thu Jun 24, 2010 10:08 pm
Yes i no tell me about it..minehas been doing it for around 4 months there must be a remedy to this.
sweep
Fri Jun 25, 2010 5:47 pm
Its been on a snap on diagnostics machine today and it came up with the air flow sensor(airflow metre) and its running lean so i have put a good known one on but its still the same :?
TouringMatt
Fri Jun 25, 2010 6:43 pm
That sounds a good machine, would be interesting to try mine on that
ECU reset?
Last time i disconnected/reset mine (throttle cable wound in) it idled cold at 1800rpm and warm 1200rpm, reset the linkage and reset the ECU and nope, 600rpm and stalling - twice today, so the cable cheat is back.
Often wander about my AFM, re-tract the arm ages ago when trying to solve another problem, but ive noticed the anti-tamper seal has sometime been removed so there is no way of knowing if its set right. From what ive read it only makes a difference at idle, once the TPS has switched.
Matt
sweep
Fri Jun 25, 2010 6:58 pm
It took a while to get into it but the snap on set up did it.is there a filter in the rocker cover which can be replaced?just wondering how it can be running lean with another air flow metre?
b17
Sat Jun 26, 2010 12:18 am
Out of interest - how do you reset the ECU? Disconnect battery for 5 mins??
StuBeeDoo
Sat Jun 26, 2010 5:12 am
b17 wrote:Out of interest - how do you reset the ECU? Disconnect battery for 5 mins??
..... Then start the engine and let it idle for 15mins.
sweep
Sat Jun 26, 2010 6:31 am
Im going to check the tappits next.
sweep
Tue Jun 29, 2010 7:23 pm
And no difference...any ideas with a last bump.
davidt
Pompey Council 4 door deviant
Tue Jun 29, 2010 7:33 pm
Have you checked the spark plugs it could be one of them is not working at low revs then clears as engine speed goes up.
sweep
Tue Jun 29, 2010 7:51 pm
I have put new plugs in it.
sweep
Tue Jun 29, 2010 9:26 pm
Now thinking of trying a fuel presure regulator
e301988325i
Tue Jun 29, 2010 10:00 pm
sweep wrote:I have tried a crank sensor today and its the same,when its running and i disconect the tps wiring plug the engine does not alter is this right?
I'm sure that if the ECU was getting the idle signal from the TPS the engine does make a noticeable differrence.
sweep wrote:just wondering how it can be running lean with another air flow metre?
they have to be adjusted to suit the car. . . on a gas analyser, idle by pass screw and internal spring tension on the black toothed whell, have to take the black cover off the top.
I said:
e30topless said:
lock the wife in there
sweep
Thu Jul 08, 2010 8:36 pm
Now solved,i removed the throttle body again and set the butterfly with a 0015 feeler guage when closed and the reset the tps to work acordingly and its now idling spot on.....so now im back in love with the old girl..treats all round! thanks guys for all the help :)
bpowell555
Thu Jul 08, 2010 11:31 pm
Good man! When you say adjust the tps accordingly, what does that mean? Reckon mine has something similar as it idles low.
Btw, alternator voltage regulator / brush pack will give the power steering a bit more juice if its causing the revs to dive ...
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
sweep
Fri Jul 09, 2010 7:22 am
Adjusting the tps acordingly..seen as i adjusted the butterfly with a 0015 feeler guage from completely shut this would activate the tps when at idle which would by giving the ecu the wrong signal so i adjusted the tps to activate from the butterflys new slightly open position.
b17
Fri Jul 09, 2010 8:51 am
This is interesting...
...i adjusted the butterfly with a 0015 feeler guage from completely shut this would activate the tps when at idle which would by giving the ecu the wrong signal
Should the TPS be activated at idle? I thought that was the point...
