The trouble is, so much talk about axle ratios goes on based on various different opinions of those with experience of what is better or worse in which circumstances. So often, there's a placebo effect, or a prejudice towards a certain outcome. It's just the nature of human reactions.hongkongfuey wrote:i think at the end of the day you can look at charts and numbers all day long, the thing is it's not going to matter utill you try one. If you put in a longer one you could say its great, but so could a shorter one too. And unless you plan to race your car ??? The other thing to look at is is your diff broken?? Is your gearbox tight, have you changed oils ,done a service lately, wheel bearings good? Lightened flywheel? Then engine mods bbtb,fiters,ecu(chip) etc. I'm not being pissy about this i just think basically its now all been said about diffs ???
I'm doing a whole load of maths now on excel, not so I can argue a point based on my findings, but so I can really relate the physics with the experience. In this thread, I've got you saying 3.64 will be no good, and StuBeeDoo saying it will be fine - who do I believe? I think I understand gear ratios, but a little research into the topic finds some of my assumptions were incorrect and so I need to do a bit more homework to understand it properly. I will have to 'suck it and see' at some point, but I want to be able to understand what I experience when I do.
