arrrrrrrrrrrrrrrrrrrrrrrrrrrgh
Martinaston
Post Sat Jul 23, 2005 7:51 pm
:thumb:
wayneE30
Post Sat Jul 23, 2005 8:57 pm
Image there you go i will post more in a minute if you want
Martinaston
Post Sat Jul 23, 2005 9:08 pm
have you got a pic looking down into the carb ?
and one from other side
wayneE30
Post Sat Jul 23, 2005 9:15 pm
yeah sure if you give me about ten minutes or so
wayneE30
Post Sat Jul 23, 2005 9:23 pm
Imagetheres 1
wayneE30
Post Sat Jul 23, 2005 9:37 pm
Image hope this one is what you mean
Martinaston
Post Sat Jul 23, 2005 9:46 pm
1. Secondry throttle diaphram assembly
6. Thermal valve
7. Does that go to the air filter housing ?
Pull the pipe off at 2 and you should get a slight suction, if your not sure put your hand over the top of the carb (venturi) for a second to block the air flow and the end of the pipe should grip your finger.
If not then remove the pipe and make sure it is clear and the tube at 4 is clear into the venturi.
wayneE30
Post Sat Jul 23, 2005 10:03 pm
ok no 7 goes in to the white box behind it in the pic (i think :oops: )
i just took the pipe off at 2 and yes there is major suction
Martinaston
Post Sat Jul 23, 2005 10:26 pm
Now with 2 back in place pull the pipe at 5 and see if you get suction with the engine stone cold and then again when hot.
wayneE30
Post Sat Jul 23, 2005 10:32 pm
there is no suction when cold
i will have to wait till tomorrow to check it when its hot as its too dark to see now cheers martin
Richy325iTouring
Post Sat Jul 23, 2005 10:48 pm
Brianmoooore wrote:
wayneE30 wrote:
i was thinking would the carb want tuning to the engine???
It possibly would if it came from a different capacity engine.
Weren't early ones 1600cc and later ones 1800cc (still badged 316)
all the carbs were 1800 cc
in regards to the relay
there should be a black box on the wing
take that off and inside it there should be a relay
im almost 100% certain that is the problem
had simular probs with my old one
got fed up in end so i just changed to the injection lump
gained 15 bhp for 100 notes as well lol
wayneE30
Post Sat Jul 23, 2005 10:57 pm
i think the guy changed that before i bought the car im gonna look for the old ebay advert i will post in a min
Richy325iTouring
Post Sat Jul 23, 2005 10:59 pm
most likly prob if yourhaving probs with a carb that was running before youbought it
take a look at it does it look new
wayneE30
Post Sat Jul 23, 2005 11:29 pm
this is a copy of the original advert on fleabay
LOVELY CONDITION 2 DOOR 316 BMW(CARB) I BOUGHT THIS CAR ON E BAY A MONTH AGO, SINCE THEN I HAVE PUT A CD PLAYER IN IT,IVE PUT 6 MONTHS TAX ON IT,ITS HAD A NEW IGNITION MODULE,NEW AIR FILTER,FUEL FILTER,2 OIL LEAKS FIXED ONE BEING FROM THE REAR CRANK (BIG JOB), THERE IS NO RUST EXCEPT FOR A TINY SPOT ON REAR WHEEL ARCH,SO SMALL I CANT REMEMBER WHICH ONE IT IS.THE INTERIOR IS SPOTLESS NO TEARS OR RIPS ITS BEIGE TRIM IS LIKE NEW,THEGLOVEBOX WONT OPEN THOUGH..(NOTHING MAJOR) THE PLASTIC DOOR LOCKS HAVE BEEN REPLACED BY ALLY ONES, IT ALSO HAD 2 NEW TYRES A BACKBOX AND RAD FOR THE MOT, THE CARB WAS REPLACED NOT TO LONG AGO EVIDENTLY ..............................................NOW FOR THE BUT..................EVERY NOW AND THEN THE CAR CUTS OUT FOR NO REASON THEN IT STARTS AGAIN AFTER THATS WHY I PUT A NEW IGNITION MODULE ON BUT IT HASNT HELPED,IT IS HAVING A TUNE UP NEXT WEEK MAYBE THAT WILL CURE THE PROBLEM,IF NOT IT COULD BE A BIT OF DIRT IN THE CARB...IM ONLY SELLING AS I NEED SOMETHING I KNOW WONT STOP WHEN ITS IN THE MOOD (MUST BE FEMALE) AS I START WORK EARLY IN THE MORNINGS.I CLASS IT AS A RELUCTANT SALE AS IT IS A LOVELY CAR.....THE CAR ALSO STILL HAS THE ORIGINAL TOOL KIT IN THE LID OF THE BOOT,THE CAR HAS NOW BEEN KRYPTON TUNED AND RUNNING A LOT BETTER IT ISNT CUTTING OUT BUT IS EVERY NOW AND THEN RUNNING A BIT JUDDERY BUT I HAVE LOWERED THE PRICE
Dan318-is
Post Sat Jul 23, 2005 11:41 pm
i dnt no much abou carbs but i would like to contribute
mymate has a 316 carb, he put some sort of webber on it which worked quite well, but that was nothing until he put twin dellortos on, i kid you not he was on par if not quicker than my mates 318i with filter and exhaust and no rear seats 8O
The moral of the story is, pierburg carbs in my experience (especially on my golf) are pieces of poo
Treeman612
Post Sun Jul 24, 2005 6:40 pm
Wayne, if it's a temp sensor that could be at fault, let me know - you can have the b**ger of my scrapper if it sorts it out - I want to find out what the problem nearly as much as you do!!!
