1.1 TO 1.3 Motronic on a 1986 325i
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Mar 29, 2012 5:43 pm
gooner1
Out humping Reindeer
Post Thu Mar 29, 2012 5:58 pm
Then, hopefully, I am very close to completion.
Will install the CPS as soon as possible and try again.
Really do appreciate all the help given btw, and Grrr, I do refer to the Wiki, but
asking questions here first gives me an idea of what to look for in it. :thumb:
gooner1
Post Fri Mar 30, 2012 2:05 pm
She cranks, she fires, she runs. :D :D :D
Will refit belts, pulleys and viscous tomorrow and use it until I'm back at work
on Wedensday.
Then I'll start to pull the engine out.
Post Fri Mar 30, 2012 2:27 pm
Congratulations fella, must be a good feeling! :P
gooner1
Post Fri Mar 30, 2012 3:13 pm
Thank's Maurice, it is indeed a good feeling. Very. :thumb:
gooner1
Post Mon Apr 02, 2012 10:48 am
Took it for a shortish drive yesterday, 20 mins approx, too intent on
concentrating on any faults likely to appear to really appreciate any differences
in the change. Got close to home and noticed a rubbery burning smell.
Popped the bonnet and the Oxygen sensor was nicely welded to the exhaust manifold.
I'm guessing that I can cut this away from the loom, and safely wrap up
any wiring from it, yes :?:
Will take it out for a longer drive today, now that all seems to working just fine.
Post Mon Apr 02, 2012 1:16 pm
If you don't intend to fit a lambda/oxygen sensor, then yes, you could cut the wires, although it may be better to leave them in place and just tuck them out of the way, should you or someone else wish to refit it at a later date...
gooner1
Post Tue Apr 03, 2012 3:13 pm
Just cable tied it out of the way for now, but think it may be beyond any
future use. My own silly fault.
As to the management change itself, i;m very impressed. Feels so much smother
and responsive. :D Highly recommend doing it.
Post Tue Apr 03, 2012 3:17 pm
Good work Rob. :D
gooner1
Post Tue Apr 03, 2012 3:30 pm
Rav335uk wrote:Good work Rob. :D
Thanks, Rav, but others should be taking all the credit for this.
I just followed their, much appreciated, advice
