Answers From The Oil Expert Part # 2
ross2009
Post Tue Mar 29, 2011 9:22 pm
hi guy
just built a fresh m20 325i thats turbo ed not been started yet tho
what do you recommend for a turbo engine? and which oil to run it in with? how many miles to run in and dump the oil? and what to run it on in future?
oilman
Zone Oil Advisor
Post Tue Mar 29, 2011 9:26 pm
To run in http://www.opieoils.co.uk/p-60229-mille ... n-oil.aspx
Once run in a decent synthetic, what kind of power are you aiming at? And what kind of use will the car see, road, track, drag, drift etc?
Guy
Use the code E30Z and get 10% Club Discount
oilman's website for engine oil and much more - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
ross2009
Post Tue Mar 29, 2011 9:40 pm
ok thanks Erm between 300 and 400 bhp it's gonna be strictly a Rd car maybe the odd drag strip to see what it can can do but nothing serious :)
oilman
Zone Oil Advisor
Post Wed Mar 30, 2011 9:09 am
Hi
I would say a good 5w-40 would probably be the way to go, unless you are getting high (over 125C) oil temps, then a 10w-50 is the best choice.
http://www.opieoils.co.uk/c-656-5w-40.aspx
http://www.opieoils.co.uk/c-659-10w-50.aspx
Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS, Motul 300V, Redline and Gulf Competition. They are all really good oils and up to dealing with the harsh conditions of trackdays.
Tim
phone: 01209 202944
ross2009
Post Wed Mar 30, 2011 8:12 pm
ok thanks i shall be buying some of that real soon how many miles do you recommend using the running in oil ?
thanks
oilman
Zone Oil Advisor
Post Thu Mar 31, 2011 9:26 am
I've always thought that the car should be run in for the first 1000 miles, some people reckon 250-300 is enough
phone: 01209 202944
mattyb
Post Thu Jul 07, 2011 10:32 pm
hello oilman iv been building an m20 turbo over the last few minths and im getting near to the big start up. the turbo im using is and hx35 journal bearing turbo and i was wondering what oil you recomend, it has an oil cooler fitted with a thermostat so it doesnt over cool, your help will be much appreciated, thanks
oilman
Zone Oil Advisor
Post Fri Jul 08, 2011 9:04 am
I think I'd go with good 5w-40 or 10w-40, but if you get it running and find that the oil temps are getting over 125C a lot of the time, change to a 10w-50.
http://www.opieoils.co.uk/c-647-engine-oils.aspx
Fuchs Pro S, Redline, Gulf Competition, Millers CFS and Motul 300V are the ones I'd consider.
Tim
phone: 01209 202944
mattyb
Post Fri Jul 08, 2011 9:29 am
ordered millers cfs 5w-40. thanks for the help tim.
oilman
Zone Oil Advisor
Post Fri Jul 08, 2011 10:04 am
Thanks for the order
phone: 01209 202944
willf
Post Sun Jan 01, 2012 6:47 pm
just read through this to find the best oil for my IS, really informative, just ordered some fuchs titan from you, thanks very much!
oilman
Zone Oil Advisor
Post Mon Jan 02, 2012 5:19 pm
Thanks for the order and glad to help out.
Tim
phone: 01209 202944
ross2009
Post Thu Mar 29, 2012 6:47 pm
hi mr oil man i bought some of your Silkolene Pro S titan 5w-40 for my turbo engine after the run in on your recommemdation no problems there
after about 3000 miles i had a big end bearing pick up and knackered my crank do you think this could be an oil related problem ? getting to hot etc ? this was on a rd not on a track too
Turbo M20
v8 project 6.0 twin turbo
Tan91
Post Tue May 08, 2012 12:09 am
Hello Mr Oilman, I have a 1990 316i LUX M40. Ive Always used 10w40 semi synthetic and was wondering is this correct as I cover around 8000 miles a year maybe more. It is changed every 12 months with a wynns engine flush thingy to remove old oil?
But I am beginning to think if I should be changing it every 6 Months?
And use 5w40 Synthetic?
Cheers, Tan.
newportimports
Post Fri Sep 21, 2012 12:27 pm
oilman wrote:For the diff, go for the Silkolene Syn 5, Redline 75w-90 NS, Castrol SAF-XO or Fuchs Sintopoid.
http://www.opieoils.co.uk/c-673-75w-90.aspx
You need an MTF for the gearbox and I would go with the Redline MTL, Amsoil MTF or Fuchs Sintofluid. The Millers EP 75w-80 is a good cheaper alternative
http://www.opieoils.co.uk/c-670-75w-80-75w-85-mtfs.aspx
Tim
is it better to use a different viscosity oil in the diff as to the gearbox then?
I have a PBMW race car, 4.10 open diff (not lsd), and the standard Gertrag 240 5 spd box. Both take a poor old beating everytime im out!
What would you recomend in this instance, and I see from earlier posts that 1.25Ltr is needed for gearbox but what about the amount needed for the Diff??
newportimports
Post Fri Sep 21, 2012 12:28 pm
and what about filters???? is there much difference in brand vs oem etc?
estoguy
Post Thu Oct 04, 2012 1:19 am
Hi there! I'm across the pond in Canada, and will be buying a 325e from my mate. It currently has 227K KM on it.
My current ride is a VW Jetta 2.0L and I've been using Shell Rotella T6 5w40 during the summer and the T5 0w40 for winter (both full synthetic) for over a year, and have been very happy with it. Would these be good oils for the eta for the same use? I'll be covering a lot of miles in the Bimmer (in my VW, I've been consistently over 40K KM for the last three years).
And the change interval should be what? I was reading earlier you recommending an 8-10K mile change (12.8-16K KM). I drive mostly highway miles... what should be an approximate interval?
Thanks!
newportimports
Post Fri Oct 05, 2012 12:12 pm
hey mr oil man havent heard back about my Diff / Gearbox questions??
oilman
Zone Oil Advisor
Post Fri Nov 23, 2012 2:01 pm
Hi folks,
With winter here and plenty of cold starts, perhaps it's time to consider changing the oil that you use in your car.
Does your antifreeze need changing?
Is your gearshift okay when cold?
Do you need something to protect your car from the weather?
Let us know if you need any advice, we are here to help. You can call us on 01209 202944, email us at sales@opieoils.co.uk, or just ask here.
oilman
phone: 01209 202944
Tusker77
Post Mon May 20, 2013 9:49 pm
Oil man whats the best oil for my 318is?
I'm just about to replace my lower sump.
oilman
Zone Oil Advisor
Post Tue May 21, 2013 9:07 am
I would use a 5w-40 synthetic and you will find those through the link below.
Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS NT/CFS, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Millers XFS, Shell Helix, Fuchs Supersyn and Mobil Super 3000 are good, cheaper alternatives.
As a budget choice, a 10w-40 will be fine and I would either go for the Fuchs Syn MC, Shell Helix, Millers XSS/Trident or Motul 6100
http://www.opieoils.co.uk/c-657-10w-40.aspx
Tim
phone: 01209 202944
