Timing chain on 318is
pmaddy00
Mon Jun 06, 2005 2:41 pm
I have managed to strip the engine & get to the chain. The Cam sprockets look ok but how would I tell if they are worn? Do I really need to change them too?
Thanx,
Peter
tomstickland
Mon Jun 06, 2005 5:12 pm
What's the job been like so far then?
I had a quick look in the Haynes manual it looked fairly straightforward?
kidsinister
Mon Jun 06, 2005 7:36 pm
When i bought my iS it had had the chain done, but the receipt contained a warning that the gear was worn and would best be fixed; however, I figure that if it was badly worn they'd have had to change it, and there's no sign of any trouble.
In short, I think you would notice on inspection if they were worn, and with a new chain, wear is less likely as the chain would not be moving around much on the gears.
Since it's about Ԛ£400 to get this done, I'm choosing to ignore it; it would probably work out cheaper to get a new engine in case of major failure...!
pmaddy00
Mon Jun 06, 2005 9:13 pm
It hasnt been straight forward as I thought. I had a little bit of a problem when trying to undo one of the bolts (water pump) just it wouldnt come off in the end I cut the head off !!
I am suprised how many srews/bolts they are!!! Good fun anyway but u need to have the right tools.
I have been following the instructions from here..
http://www.esatclear.ie/~bpurcell/318istimingchain.html
