Torque spec for valve cover
ian332isport
- Contact:
I believe the official figure is only 10Nm which is a bit less than 10 lbs/ft.Borderbmw wrote:The figure quoted is 9-11 lbs/ft but as long as you tighten it down evenly and dont use a 24" breaker bar you/it should be fine.
It's not quite that critical on the M20 that has studs and nuts, but on the 318is which has special bolts with rubber washers, it's very important not to overtighten or the M6 thread in the head casting strips very easily.
Ian.
