CAN FITTING A NEW AF AFFECT DRIVING ON E30??
j4ttluv
Sat Nov 24, 2007 2:52 pm
If any one could let me know, i just recently had my Air filter changed on my e30 320i and since then the car keeps jerking back n forth or it would just cut out whilst driving or station?? can this be because the car needs tuning up because there is a new Air Filter Put in? if any one can let me know...thanks...
appletree
Sat Nov 24, 2007 3:01 pm
Hi, it will more then likely be from a rubber hose thats been disturbed when it was changed or cracked from being bent. check all the clips are tight and that the hoses are all pushed on properly. :D
hope that helps
mrLEE30
Sat Nov 24, 2007 4:25 pm
also check the hose from air flow meter to the inlet, this is the most likely place where if disturbed you get an air leak, this allows un-metered air into the engine and it will run rough
j4ttluv
Sat Nov 24, 2007 4:58 pm
ok kool will give it a try!!
Nelly
Gumbo
Gumbo
Sat Nov 24, 2007 5:02 pm
Plus the ECU needs to adjust to a different AFM, the setting on it might be slighty different to it's original - it shouldn't take long.
But if you've got an AFM from a 2.5 on there it'll buck all over the place all the time.
"I F**KING LOVE YOU GUMBO"
Sat Nov 24, 2007 10:16 pm
As mrLEE has already said, it's almost certainly a split in the big air hose between the AFM and throttle body. It has to be bent through 90 degrees to change the filter, and, if perished, will split.
Nelly
Gumbo
Gumbo
Sat Nov 24, 2007 10:34 pm
Holy cow - why i ask my self did i read it as AFM?????????? plonker!
Sat Nov 24, 2007 10:53 pm
Nelly wrote:Holy cow - why i ask my self did i read it as AFM?????????? plonker!
I put it down to being a Saturday night, and a few members becoming a little lubricated (although a bit early yet).
j4ttluv
Sun Nov 25, 2007 1:25 pm
How do i adjust the ECU to the AFM settings?? because alot of people have said the same thing? or do i have to go to a mechanics or bmw specialist for that?
Sun Nov 25, 2007 4:04 pm
j4ttluv wrote:How do i adjust the ECU to the AFM settings?? because alot of people have said the same thing
A lot of people have no idea what they're talking about! No such adjustment! Ignore.
snoops
Major Helmet
Sun Nov 25, 2007 5:42 pm
:rofl:
j4ttluv
Sun Nov 25, 2007 7:40 pm
ok, but then why wud i take yo advice if ive had over 30 peopel say that same fing 2 me abotu adjusting ecu cuz of new AFM??? not sayin it in rude way just want to know wat experience u have of that??
Sun Nov 25, 2007 9:15 pm
First of all, what new AFM? OP says you changed the air filter!
Secondly, there are no adjustments to adjust on the ECU.
There is an adjustment on the AFM, but this only has one correct position, and only has a significant effect at idle.
maxfield
Sun Nov 25, 2007 9:18 pm
j4ttluv wrote:ok, but then why wud i take yo advice if ive had over 30 peopel say that same fing 2 me abotu adjusting ecu cuz of new AFM??? not sayin it in rude way just want to know wat experience u have of that??
Because Brianmoooore knows more about E30's than Mr Kipling knows about cakes!
PS,
j4ttluv
Sun Nov 25, 2007 11:29 pm
ok kool...just asking...didnt know of your expertise das why i asked..thanks for the help!! and i didnt mean to sound rude or say it in a rude way...
Nelly
Gumbo
Gumbo
Sun Nov 25, 2007 11:35 pm
Appologies to all above - i seem to have royaly screwed this one by not reading the title properly.
Sorry, Neil.
