abs warning light
jamesh1977
BEWARE Zone Thief
Sun Apr 08, 2007 9:10 pm
during normal driving the light is fine but if i get a wee bit playfull winkeye the light comes on.. ive noticed it seems to come on when i hit a bump if this helps.. any one any ideas ?
Templ8e30
Sun Apr 08, 2007 9:34 pm
Sounds like the same fault I have, all is fine until I steer on full lock or hit a speed bump then the light comes on :(
I've found one of the sensors has a dodgy cable, I checked the resistance out with a meter and found the resistance changes considerably on the nearside front when cable is flexed.
New sensor on the shopping list.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
jamesh1977
BEWARE Zone Thief
Sun Apr 08, 2007 9:36 pm
are the sensors a dear buy ? somthing i have never done before
Templ8e30
Sun Apr 08, 2007 9:46 pm
They're expensive new from the dealer, about £90 each.
I posted a wanted ad on here and have a replacement coming from Spadge.
Cheers,
Iain T
jamesh1977
BEWARE Zone Thief
Sun Apr 08, 2007 9:49 pm
cool will try that one once i have the cash sittin whats the going rate for second hand ones
Chris-W
Sun Apr 08, 2007 10:06 pm
Let me know if you need any - £7 each or £20 a set posted.
jamesh1977
BEWARE Zone Thief
Sun Apr 08, 2007 10:08 pm
sounds good chris will give you a shout at the end of next month if thats cool with you ?
texas2201
Sat Nov 17, 2007 8:50 pm
Hi Chris
do you have two front ones? would be interested in having a couple
Martin
