How easy/whereabouts, 325i fuel pump!
Endless325
Tue Nov 06, 2007 6:48 pm
Hi all, how easy to replace and whereabouts is a 325i touring fuel pump?
(I know, I know, I'm on the hunt for a Bentley repair manual!)
ed325i
Tue Nov 06, 2007 6:50 pm
Under the rear seat there is a plate that you remove to get to the pump.
jam172
Tue Nov 06, 2007 6:54 pm
Fuel pump is in the tank, access under the rear seat base, a plate with 4 screws on the offside of the car, remove the bolts and withdraw the sender in the centre and the remove the perimeter bolts, turn and remove the pump.
An E30 touring, two E28 M5's and an E28 528i.
Tue Nov 06, 2007 9:21 pm
Slight complication on a touring is that the fixing/hinge rail for the rear seat bases (just) gets in the way.
Slacken off three (or four??) hex headed grub screws and slide/twist the rail out.
320Touring
Tue Nov 06, 2007 9:28 pm
http://www.e30zone.net/modules.php?name ... chfuel.htm
the link above is a basic guide
as Brian says, the touring seats do get in the way a bit...
fuzzy
He who sleeps with "Gingers"
Tue Nov 06, 2007 9:32 pm
easy to replace once located. couple of rubber fuel pipes and an electrical connection to unplug and a 3 or 4 small bolts to remove the pump. cost of a nrw pump is rather high if youve not looked into that yet. £150+ ish iirc even from ECP 8O
Endless325
Tue Nov 06, 2007 10:33 pm
Thanks for all the help guys, doesn't look like too much of a bad job!
fuzzy, £150 for a new pump 8O
I've found a good second hand one from a low mileage motor for £20 delivered
fuzzy
Tue Nov 06, 2007 10:41 pm
problem with second hand though is its a gamble on how long it lasts. you might be lucky and get years of use from it but alternatively it might pack in a week after fitting it as its likely to be as old as the one your replacing.
Endless325
Tue Nov 06, 2007 10:49 pm
Very valid point mate, I may ask him if he has another one just in case :wink:
