320 not starting help please Mr Moore
SPADGE
Thu Nov 01, 2007 12:53 pm
Hi Brian
I have a G plate 320i Auto here that has been fine until this morning when it refuses to start or even fire properly.
The fuel pump is working fine as i have fuel both into and out of the rail.
I have a good healthy spark at the plugs.
Took number 1 plug out and even after a lot of cranking its near enough dry!
My guess is the injectors arn't firing for whatever reason?
Any help appreciated please as i want to move the turd off my drive :?
Cheers Spadge..
Thu Nov 01, 2007 1:47 pm
Check for ignition on power at the red/white wires on the injectors. If not present, then the chief suspects are the injector loom plug and socket (and under the lower rubber boot), and the DME relay.
Check the DME relay clicks as you unplug it and plug it in with the ignition on.
SPADGE
Thu Nov 01, 2007 2:09 pm
Hi Brian cheers for the reply.
I've just checked and the DME relay is clicking when you remove/insert it with the ignition on.
The red/white wires have 12v+ to them also.
Anything else :?
**BANNED**
Thu Nov 01, 2007 3:21 pm
Starter inhibit switch?Auto box in neutral/park?
Youth is wasted on the young.
frankiej
Thu Nov 01, 2007 3:29 pm
Woah, woah now Spadge... I'm supposed to be the only one in the Zone that has a 320i that doesn't start. winkeye
No A/C, no PWR steering, no ABS... It's a race car! '89 320i Touring / DiamondSchwartz Metalic
ed325i
Thu Nov 01, 2007 3:52 pm
It wouldnt turn over.
SPADGE
Thu Nov 01, 2007 3:55 pm
Well after exploring all avenue's and only finding a knackered 'non existant' carbob brush in the dizzy cap its now sorted :D I can't understand why 2 of the 6 plugs i tested had a great spark but i've changed the cap and rotor and its now running sweetly 8)
Thanks for the guidance fella's!
fugazi33
Thu Nov 01, 2007 4:00 pm
:cool: So the rotor was fecked as well then!
SPADGE
Thu Nov 01, 2007 4:22 pm
fugazi33 wrote::cool: So the rotor was fecked as well then!
Yes mate bolloxed for want of a better word :D
PS Cheers for lending a hand earlier mate :thumb:
fugazi33
Thu Nov 01, 2007 4:33 pm
No worries dude, anytime :D
SPADGE
Thu Nov 01, 2007 6:02 pm
Check this cap out!
I can't belive it ran so well just yesterday :eek:
Not the bit of 'ventilation' this was already like this :?
Thu Nov 01, 2007 11:59 pm
SPADGE wrote:I have a good healthy spark at the plugs.
...... after a lot of cranking its near enough dry!
SPADGE
Fri Nov 02, 2007 12:03 am
I honestly pulled plugs 1 and 4 out before removing that cap and they both had a very healthy spark!
And yes the plugs were dry at that point also so unless i entered the twilight zone this afternoon i must have disturbed something that made the injectors work again :mad:
Very strange i must admit :?
Andyboy
Alpina Colada
Fri Nov 02, 2007 9:15 am
That cap just had to be the original! My old blue thing had it's first cap in 270+ thousand miles 2 months ago - still had the '89' date stamp. It started okay but had a horrible misfire under load. The KV's obviously weren't enough to get it going.
I trust you bought a genuine new cap from Victoria BMW then? winkeye
fugazi33
Fri Nov 02, 2007 9:33 am
That cap actually had '87 stamped in it, so it was older than the car!
Andyboy
Alpina Colada
Fri Nov 02, 2007 10:13 am
fugazi33 wrote:That cap actually had '87 stamped in it, so it was older than the car!
"The previous recorded keeper is, Pacerpete................." winkeye
SPADGE
Fri Nov 02, 2007 12:12 pm
Andyboy wrote:That cap just had to be the original! My old blue thing had it's first cap in 270+ thousand miles 2 months ago - still had the '89' date stamp. It started okay but had a horrible misfire under load. The KV's obviously weren't enough to get it going.
Lol its not called Victoria anymore its part of the 'Stratstone group' now :P
I of course put on one of my selection of used caps which in fairness did look barely used :D
As fugs said above the cap was older than the car :mad:
Andyboy
Alpina Colada
Fri Nov 02, 2007 3:52 pm
SPADGE wrote: Lol its not called Victoria anymore its part of the 'Stratstone group' now
Stratstone are everywhere now - part of the Pendragon group who also own Evans Halshaw and others. The only company that won't deal with them is VAG, a resident of The Keynes for a long time . :D
