The car will normally start 1st time in the mornings, and then start to stutter slightly when you keep starting and stopping (i.e. short journeys).
Over the last few days when it's got colder it's now getting worse, and sometimes you turn the key and nothing happens.
Swapped the battery over with the one from my 316 but that wouldn't start it....
however if i jump start the car, then it'll start 1st time!
I'm pretty sure that it's the battery as once started i my brother disconnected the power cable (only for a few seconds to test), to the battery and the car kept running so i'm guessing the alternator is okay, and the starter isn't clicking or anything so i presume that's okay.
Basically what i want to know is what Ampage battery should this engine have?
This is an annoying problem and i want to get it sorted asap with winter coming up if the batteries weak it's just going to get worse
Thanks for your replies in advance.
