Hi
Rear washers are not working on my Touring, traced the fault to the rear washer motor (it was blocked with rust & cleaned this out), where the washer pipe goes into the elbow on the motor, it's leaking water there, can this be fixed or is a new motor required ???
Tom
Touring Rear Washer Motor Leaking
BadDave
If it's the actual plastic elbow then it can be superglued back on.
If it's where the pipe fits over the elbow then trim about 1/4" from the endof the washer pipe and then refit it.
