Is My Steering Rack Rogered?! UPDATED with pics!
Endless325
Thu Aug 09, 2007 9:44 pm
Today, idling in traffic, I smelt something, smelt a bit strange, dismissed it as something irrelevent, then, my car started smoking from the underside.
I pulled over and had a look, and from what I could see, it was my power steering fluid leaking and burning on something, I guess it was leaking from my rack.
I haven't had a chnace to get under it and have a good look yet, but is it time for a new rack, or could it be something else? (hopes and prays)
Thu Aug 09, 2007 10:00 pm
If it's the exhaust side, which I presume it is because of the smoke, then it could be a loose banjo connection, but if the bellows on the end of the rack has any fluid in it, then it time for a change of rack!
Endless325
Thu Aug 09, 2007 10:11 pm
Thanks for the reply Brian, I will have to get underneath it and have a look, out of interest, what is the standard labour charge for replacing a rack?
Also, this's what you mean by bellows right?
Thanks again 8)
Thu Aug 09, 2007 10:18 pm
That's the bellows! Usually a small hole about half way along somewhere, and the fluid will squirt out there when you turn hard left, or even push the bellows off the end of the rack.
Endless325
Thu Aug 09, 2007 10:29 pm
Thanks Brian, fingers crossed!
Endless325
Tue Sep 04, 2007 1:07 am
smithy318i
Tue Sep 04, 2007 1:38 am
Endless325 wrote:OK, since this has happened I have left the car in the garage as I haven't had much time recently, today (some 3 weeks later!) I got underneath the car to have a nose around.
Now as far as I could tell, the bellows didn't have any fluid in them (I gave them a good squeeze) but there was some fluid on them as you can see in the pics, but everything down there seems to have a bit of fluid on it. Other than that, I don't really know, as I'm not sure what I should be looking for?
Here are the pictures
This is what greeted me after I moved the car
And the rest
Cheers 8)
Jetwash all of that sh!t off and you will be able to see the source if the leak.
Endless325
Tue Sep 04, 2007 10:11 pm
Cheers for the pics, and the advice, if anyone wants to see full size pics, please click on the links in my post.
So, anymore advice anyone winkeye
Martinaston
Tue Sep 04, 2007 11:00 pm
Looks like the pipe connections are leaking, don't bother trying to tighten them you'll just bugger the thread up.
Get new crush washers, two for each bolt and fit them. Give it a jet wash first to be sure though as you may have a punctured pipe.
There is NO nucleus.
Endless325
Wed Sep 05, 2007 10:53 pm
Are there any tips, as space is a bit tight down there?
Martinaston
Wed Sep 05, 2007 11:19 pm
I think with it in the car still you have to use spanners as a socket set is a bit awkward.
Endless325
Tue Sep 11, 2007 10:54 pm
Cheers mate, I gave that area a jetwash, but still can't see where the leak is coming from!
Martinaston
Tue Sep 11, 2007 11:14 pm
At a guess its that clean one, but i'd just replace all the washers anyway.
