Clutch Fluid Reservior / pipe
paulf
Thu Aug 09, 2007 7:13 pm
Hope someone can help with this,
the pipe which leaves the bottom of the clutch fluid reservoir on my 318is is all rotten ( guessing fluid leak has caused this?) The pipe appears to go into the bulkhead at a totally inaccesible point, just below the battery tray. Has anyone on the zone ever managed to change this ?
Also have a fluid leak from near the gearbox , am i right in assuming that i'l be needing a new slave cylinder as well ? :cry:
Paul
Chris-W
Thu Aug 09, 2007 7:15 pm
The hose is actually a doddle to change - just pushes on to the master cylinder. It's quite usual for the cloth outer sheath to be frayed - is the rubber rotten?
Your slave certainly sounds to have failed, and you should really change both master and slave together.
paulf
Thu Aug 09, 2007 7:20 pm
thanks chris,
it is possibly just the outer sheath then, fingers crossed, although if i'm doing both cylinders, i guess it'l be best to change the pipe as well if its that easy.
Would ECP parts be ok for cylinders do you think?
Chris-W
Thu Aug 09, 2007 7:53 pm
From memory I think they offer two options for both - go for the more expensive ones.
mattG
Thu Aug 09, 2007 10:01 pm
Just changed my slave cylinder after getting stuck on a busy around about :cry:
I got mine from ecp the dearer one at 22 quid the cheaper was 18 :roll:
It only took half an hour to do, the top bolt was fidley i used a long reach scoket+UJ on 1/2"drive ractet.
paulf
Sat Aug 11, 2007 7:22 pm
thanks guys,
will get cracking next week
paul :)
