strange problem with clutch
cro320
Thu Aug 02, 2007 5:58 pm
I am not sure is this really a problem or I am bad driver :-)
Anyway, since I bought the car problem apears as follows:
when I drive in reverse, car doesn't move smooth, it stalls.
I am giving my best to describe this, not perfect english speaker :D
I select reverse, releasing the clutch slowly with about 1000rpm and it move ok, but when I try to press cluth I can hear the ''clunk'' sound from behind.
Also when moving in reverse with pressed clutch to the floor, and then trying to release it a little to continue moving it ''kicks'' one or two times and clunk noise is hearable again. I really think that I have bad driving technique, but I drove lot's of E36/E34/E46 cars and never noticed any problem like that.
Any help would be great
Gwynleym10
Thu Aug 02, 2007 9:50 pm
It might be your rear differential bush - This makes a loverly clunking noise when you engage reverse if it is dead.
Pretty simple to replace - if you drain the diff of oil and just remove the cover.
London 2 Cape Town
www.Overlandinthesun.com
cro320
Thu Aug 02, 2007 11:46 pm
it doesn't sound when selecting reverse, it clunks when clutch fast pressed to the floor
Martinaston
Fri Aug 03, 2007 12:04 am
Take the handbrake off.
There is NO nucleus.
siddiqi1
BFG Zone Contributor
Fri Aug 03, 2007 1:16 am
lol
gorgeee
Fri Aug 03, 2007 2:01 am
i had a mk1 golf years ago and same used to happed because the engine mounts had gone and were loose?maybe that can help bruv
Black Sport
bazza93
Fri Aug 03, 2007 12:27 pm
centre bearing, ?????
will be back in an E30 oneday soon !
THE BMW 3-SERIES. IT'S WHY SOME ENTHUSIASTS ARE MORE ENTHUSIASTIC,
cro320
Fri Aug 03, 2007 1:54 pm
center bearing NEW, engine and gerarbox mounts NEW, handbrake off LOL :cool:
Let's try like this: when clutch pedal lifted off with small engine power (800rpm cca) and driving in reverse, then fast pressed clutch to the floor makes a noise like ''clunk'' hearable somewhere between diff and drive shaft. But everything is fine in normal driving :roll:
bazza93
Fri Aug 03, 2007 1:56 pm
rubber doughnut between gearbox and prop :D
Martinaston
Fri Aug 03, 2007 2:11 pm
Check the bushes on the rear axle, the two at the sides and the one on the back of the diff. Possibly starting to wear or the rear brakes are dragging.
Let the car roll to a stop in reverse on level ground and just as it stops if the suspension rises slightly they'll need checking.
cro320
Fri Aug 03, 2007 3:28 pm
bazza93 wrote:rubber doughnut between gearbox and prop :D
maybe, but mine looks as new :?
Ant
Retired Team Member
Retired Team Member
Fri Aug 03, 2007 7:48 pm
Hmm
LSD diff ?
a worn diff would judder badly in reverse, is it worse when reversing with steering on lock right or left ?
cro320
Fri Aug 03, 2007 9:35 pm
no LSD diff.
It's not that bad, only thing is that I need to be very fine on clutch, otherwise will clunk
Gwynleym10
Sat Aug 04, 2007 9:30 pm
Is the clunk all the time, or just when the engine is hot? Is it more or a judder than a clunk? If it is then it might be worth changing your clutch fluid.
London 2 Cape Town
cro320
Sun Aug 05, 2007 12:23 pm
god damn man :cool: , I've changed clutch fluid a month ago.
Things I haven't replaced are diff oil and this rubber between gearbox and shaft. Well it's cheap so I could replace them next week and see for changes :wink:
cro320
Sun Aug 05, 2007 4:46 pm
just back from garage...I put car in neutral and tried to move drive shaft by hand, when I trying to roll it, it has about 0,5cm free play.
What should I replace?
