Had a bit of an accident this morning on the way to work and kirbed the car on the passenger side really badly............ouchhh!!! Honestly Only doing 30mph, sun was in eyes and BANG!!!! you can guess the rest!!!
"THIS WAS THE WHEEL"
IMG]http://i168.photobucket.com/albums/u190 ... ics009.jpg[/IMG]
ANYWAY....At first the car was drivable but shuddered quite a bit but managed to get it home and left it there till after work.
Took the wheel off, nothing out of place on first inspection looked fine, nothing loose, hub was good, disc was good, TCA good, d/shaft good, followed up the strut & spring and that looked all in tacked, all was fine, then i looked at the strut top mount under the bonnet and noticed the 3 bolts were not as straight when compared to the other side, obviously its had a bit of a smack, but please look at the photos and you'll see wots up!!
"DRIVERS SIDE -TO COMPARE"
"PASSENGER SIDE WHERE I HIT....LOOKS LIKE THEIR ON AN ANGLE EH??"
Thought i'd wrecked it, but wot i did was, put a perfect spare wheel on and went for a drive, thinking the tracking was going to be out, and tALL SORTS!!!!
BUT IT WAS ABSOLUBTLY FINE TO DRIVE.....SAME AS BEFORE, DIDN'T SHAKE, SHUDDER OR PULL TO 1 SIDE, AT SPEED OR GOING SLOW, LOCK 2 LOCK WAS PERFECT AS BEFORE, NOT A THING WRONG...PROMISE!!
NOW... is it going to be ok, is there anything else i should look for??? PLEASE, just for piece of mind, MOT is this Saturday.....I'M BRIKKIN' IT NOW!!!
CHEERS
