Heater failier
Sanchez
Sun Jul 29, 2007 5:55 pm
Well my heater doesnt work.
Theres no water under the passenger carpet but the car is losing water from the radiator but cant see where.
Theres no 'mayo' on the oil cap..
Can anyone put their finger on my problem?
gazza
Sun Jul 29, 2007 6:02 pm
the heater valve that is electric has stopped working or the wire has come off ....its down on the side of the matrix to the right side of your glove box
or did you mean its stopped blowing ...but if there is no heat i would try the valve first as well as checking for any air locks
someguy
Sun Jul 29, 2007 6:54 pm
you should hear the valve click when you turn the heat up, as in when you move it from fully cold.
Have you changed the coolant recently? has it been happening for long?
It could be an airlock.
Sanchez
Sun Jul 29, 2007 6:55 pm
yep
did a coolant flush recently.
Didnt really notice when it stopped, supposidly being summer time and all that.
someguy
Sun Jul 29, 2007 7:07 pm
You've probably got an air lock somewhere in the heater matrix. not exactly sure how you cure this but I'm sure someone'll let you know soon!
Sanchez
Tue Jul 31, 2007 11:17 am
how can i solve an air lock then?
Tue Jul 31, 2007 5:19 pm
undo the bleed screw on your rad at the top next to your expansion cap, turn engine on with your heater on hot and at number 4 with all the vents open, let the engine run up to temp, keep an eye on the level and top it up once the air lock is out. This should do the the trick
Sanchez
Thu Aug 02, 2007 11:59 pm
Simon13 wrote:undo the bleed screw on your rad at the top next to your expansion cap, turn engine on with your heater on hot and at number 4 with all the vents open, let the engine run up to temp, keep an eye on the level and top it up once the air lock is out. This should do the the trick
would that have anything to do with losing water?
Fri Aug 03, 2007 5:17 pm
how do you mean? you're going to lose some water before the airlock comes out yes, assuming this is your problem or you don't have a leak anywhere on the coolant system
