ALPINA CHIPS
DANGEROUSuk
Hi i want to install a chip in my ecu how do i do it and will it make alot of difference to performance and how much would i expect to pay for 1.ty
There are some on ebay from lithuania are they any good ?
I have BOCSH/MOTRONIC 0.261.200.380 ecu.
shedrool83
DANGEROUSuk
Hi ty do have 1 in ur e30 does it make alot of difference?
shedrool83
DANGEROUSuk
k thnx m8
dimebag_from_hell
I got a wild chip in mine, seems to be good, only thing is it revs right through the red......funny they dont sell them anymore....
tailoutcharlie
ants mild chip is sposed to be good improves the mid range or something, thinking about one myself...when funds allow of course
Chris
DANGEROUSuk
How much do they normaly go for ?
hongkongfuey
- Mad-tango-geezer
hello i got a racing chip from usa, it says it gives 18-20 hp and 15 lb-ft torque rev limiter upped to nearly 7000
i've got a 325i and it definately made a difference.
the chip i'm going for now is from seller on ebay called " innovative-autosports" , it states it gives 24+ hp and 20lb-ft torque and raises rev limiter 400 revs . it only costs £19.70 = £2.95 postage so for £25 for that power its worth trying
hope that has helped
with cars like mine,
DANGEROUSuk
k ty m8 ill search it out
snoops
- Major Helmet
if it raises the rev limiter another 400 revs then it won'traise it if you have the usa chip in as that has already raised ithongkongfuey wrote:hello i got a racing chip from usa, it says it gives 18-20 hp and 15 lb-ft torque rev limiter upped to nearly 7000
the chip i'm going for now is from seller on ebay called " innovative-autosports" , it states it gives 24+ hp and 20lb-ft torque and raises rev limiter 400 revs . it only costs £19.70 = £2.95 postage so for £25 for that power its worth trying![]()
hongkongfuey
- Mad-tango-geezer
what i ment was it raises the revs 400 not an extra 400 and i will be replacing the chip i have with this upgraded oneif it raises the rev limiter another 400 revs then it won'traise it if you have the usa chip in as that has already raised it
yeah alrighthongkongfuey wrote:hello i got a racing chip from usa, it says it gives 18-20 hp and 15 lb-ft torque rev limiter upped to nearly 7000
d6dph
That's what's commonly known as bullsh*t figures mate.hongkongfuey wrote:hello i got a racing chip from usa, it says it gives 18-20 hp and 15 lb-ft torque rev limiter upped to nearly 7000
You will be lucky to get 8-10 hp at most. Speaking from experience.
The only place I would recommend to buy a chip from is A-tech (user name is Ant)
Ant
- Retired Team Member
- Contact:
Sig binned Dave.
agreed on the chip, those are bold claims from a chip swop. BS anyone
Email FTW
DANGEROUSuk
Hi ant can u sort me out wth a chip pz?
hongkongfuey
- Mad-tango-geezer
Time to wheel this old chestnut out Ant
