325i afm hose updated with pic
snoops
Major Helmet
Sat Jul 07, 2007 8:18 pm
where can i get the black hose that goes from the afm to the throttle body as mine is ripped?
what are the effects of a ripped afm hose? can i tape it up?
Simon
Sat Jul 07, 2007 8:24 pm
Buy a new one from BMW, or zimmerbimmer on here, a new one is only about £12.
Sat Jul 07, 2007 8:26 pm
From zimmerbimmer1. Give him a shout.
Give him the last seven digits of your VIN, as there are variations.
Symptoms are severe hesitation when accelerating and possible molten pistons.
dj888
Sat Jul 07, 2007 8:27 pm
molten pistons? are you kidding me? why? 8O
snoops
Major Helmet
Sat Jul 07, 2007 8:30 pm
thanks for the replys, has anyone got a part number as I really need one as soon as possible and wanted to get one on monday
Weak mixture
Sat Jul 07, 2007 8:31 pm
snoops wrote:thanks for the replys, has anyone got a part number as I really need one as soon as possible and wanted to get one on monday
dj888
Sat Jul 07, 2007 8:34 pm
or you can check-out realoem.com to confirm the part no.
Simon
Sat Jul 07, 2007 8:35 pm
As Brian says, a part number is not possible, it depends on the shape of the ICV, and some have a take off for the vacuum pipes for the brakes.
snoops
Major Helmet
Sat Jul 07, 2007 8:46 pm
:cry: my car was originally a 320 it was converted to a 325i, how will I be able to tell?
dj888
Sat Jul 07, 2007 8:53 pm
take a pic and post it here. there are two types of icvs the L type and the T type which is more affordable.
Sat Jul 07, 2007 8:55 pm
snoops wrote: how will I be able to tell?
By noting the VIN of the donor car!
In the absence of that, is the ICV L shaped or T shaped, and is there a branch that goes to a brake servo valve?
snoops
Major Helmet
Sat Jul 07, 2007 9:53 pm
has anyone got a picture i can refer to, no idea about the icv as the car is at the garage,the engine is pre facelift if it helps?
davidt
Pompey Council 4 door deviant
Sat Jul 07, 2007 10:28 pm
This is the one on a 325i face lift model I believe this is a T type.
snoops
Major Helmet
Sat Jul 07, 2007 10:32 pm
i think it might be that, ill take a picture tomorrow and host it
snoops
Major Helmet
Sun Jul 08, 2007 6:24 pm
zimmerbimmer1
BMW Parts Meister
Sun Jul 08, 2007 7:49 pm
Part number you require is 13.71.1.708.800
Will check stock for you tomorrow
snoops
Major Helmet
Sun Jul 08, 2007 8:03 pm
thanks
