exhaust sensor question
- Brianmoooore
Only electrical device I've ever seen on an E30 exhaust system is a O2 (lambda) sensor.
What makes you think there's a temp sensor?
- Brianmoooore
That is indeed a temp sensor, but since it's only fitted to Japanese spec. E30s, I've never seen one, or am ever likely to!
No idea what it's for.
				Ant
- Retired Team Member
- Contact:
Hmm, an O.E EGT thermocouple,   must be there to protect the cat from overtemp, from sitting in all those jams
most modern Audi's run an EGT setup under closed loop, its almost a better method than an 02 sensor, but only almost
Original performance chips, original works not unlicensed copies Email FTW
 Email FTW
 Email FTW
 Email FTW- zimmerbimmer1
- BMW Parts Meister
Correct it is an extra sensor for monitoring the catalyst temperature for japanese spec vehicles.
				Turbo-Brown
- Boost Junkie
- Contact:
Running an EGT and a WBO2 is a great way to see what sort of fuel AND ignition advance you can get away with.
The new Emerald can use the VAG EGT sensors as a trigger to retard ignition timing a bit, add more fuel and/or lower boost if the EGTs start getting out of hand.
