Grinding noise under the bonnet
J_Mac
Thu May 03, 2007 4:09 pm
ok fellow zoners some help would be great :)
I have a grinding metalic noise coming from the frong of the engine, first though, water pump but i've changed that and its still there, tried the broom stick handle method but can only really locate it to the front middle-lower.. alternator is new + i ran it for a few secs without the waterpump/alternator belt .. still there :( any rough idea's
320i 1989
march109
Thu May 03, 2007 4:17 pm
I reckon something is fooked!
does it get louder/faster under load?
J_Mac
Thu May 03, 2007 4:28 pm
It used to before the waterpump change only grind between 1000-1500k revs.. Yes very stange that it would stop after 1500k revs, not really been able to check it properly in that way but still definatly grinding
wildeian
Thu May 03, 2007 4:33 pm
Have you still got the engine stripped down?
Behind the crank pulley there is gear inside the housing on the outside of the engine block.
Could be debris stuck in there??
ed325i
Thu May 03, 2007 5:02 pm
Could be the cam belt tensioner bearing.
J_Mac
Thu May 03, 2007 6:33 pm
Ok it was here, touching so lightly but making such a horrid noise, in the last pic the back edge is so sharp, like a knife edge, is it suppose to be rounded like the other edge on it
wildeian
Thu May 03, 2007 6:37 pm
Mine did that for a bit, making a grinding noise. I sprayed them with wd40, and the noise hasn't come back. I'll check the state of the pulley and let you know...
J_Mac
Thu May 03, 2007 6:41 pm
nice one mate, i used card as a washer, only 1mm think and has sorted it, must be something with the new water pump being that slight bit shorter, i bought it from GFS
wildeian
Thu May 03, 2007 6:54 pm
Not a great pic, but it does show that yours is ok (flat on one side, rounded on other)
HTH,
Ian
