Im a begginer at this so firsly since there are so many people complaining about a possible blue sensor fault i thought with a bit of help put a good link on here with pictures to later help others.
Firstly my problem is the car is running at 21MPG, ridiculous with the cost of fuel these days but also its just not right.
My thoughts are,
1. air flow meter or air leak - RULED OUT
2. an obvious petrol leak from fuel pipes - RULED OUT
3. oxygen sensor - RULED OUT (none exist on non-cat converter cars)
4. my adjustable fuel regulator may be at too high fuel pressure ie >3BAR
5. Blue coolant temperature sensor
6. temperature coolant switch
7. ECU may be chipped from previous owner - I think ruled out as its a motronic casing.....unless chip was changed inside...too afraid to tamper with this!
Ok, how do i test these? (POINTS 5 and 6 ABOVE)
I just bought an ohmmeter, do i just put the meter on the Ohm section >1, then place each pointer and the temp sensor, there are two prongs on the sensor, do i just unscrew the sensor from the engine completely, and put each pointer seperately on the two prongs??
Could blue temp sensor affect the fuel consumption? exhaust fumes smell very petrolly!!!! but inside car you can smell it only from the outside at the exhaust. either way its burning rich right!!
