gortour wrote:If the lock is jammed at horizontal and the passenger door lock works
This is precisely the case.
So I guess I'll try removing the lock, and have a look at it.
Brianmoooore wrote:The most probable cause for your problem is that the driver's lock barrel has been changed at some time, and you don't have the key.
Have you contacted the previous owner?
No, I haven't, and I'm not sure I can. I just accepted it as a quirk of the car, that I'd investigate when i could
This wouldn't necessarily explain the horizontal position, though, would it?
If I get the lock out, is there any way of examining it to check if it matches the key (and the passenger's side lock) or not?
PS Brian - you never know, we may be distant relatives - my 'M' stands for Moore...
