'tapping' engine
bmwe30mtech
What engine is it? If a 1.6 or 1.8 M40 then in reality there is nothing much to be done. Live with it, despite it being really annoying!
- Brianmoooore
BMW don't do 'high mileage' engines!munky30 wrote:castrol high mileage engine oil
You can get all sorts of addatives...i used some from halfords, was in a purple tin.... works quite well when the car's upto temp.....really noisy when i first turn the key though
How would you adjust the tapets???? I've only had time to service mine, and the odd bits and bobs....not looked at engine sincejust adjust the tappets mate, mine were quite bad so spent an hour adjusting them earlier and it sound much better already
Breaking 325i Touring
Someone has told me of a trick to block out this noise when you're driving, i haven't tried it yet, but I have been assured it works.
Basically, you get a blob of blue-tack and stick it on the nut on the end of your steering column under your steering wheel centre cap. Apparently this gets rid of most of the engine noise from within the car!!!
Templ8e30
Renton, the blue tack trick works a treat
Push it firmly over the steering wheel nut so it covers the hole in the end of the shaft, stops the tapping noise from coming up though the hollow shaft.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
slinky2000
- Location: Ireland - North(Portadown) and South (Limerick)
- Contact:
blue tack, I must give this a try!, lol
what about the noise outside the car????Basically, you get a blob of blue-tack and stick it on the nut on the end of your steering column under your steering wheel centre cap. Apparently this gets rid of most of the engine noise from within the car!!!
slinky2000
- Contact:
just an example mate, now does it compare to this sound:
mine gets louder as i rev higher....not sure what it sounds like on the outside...may have to get ma mate to rag my car about so i can hear it!!!slinky2000 wrote:just an example mate, now does it compare to this sound:
