M3 Ft crossmember common to all E30's???
If not I need a M3 crossmember
Where can I get one?
Templ8e30
99% certain that all models of E30 use the same front subframe.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Thanks... I hope so. So should be easy to get one?
what you done to it, did you rip out the sway bar tabs?
Don't know is was done before I bought, been knocked back into line. Needs another one.
Demlotcrew
The later M3's had a different front crossmember to any other E30 and are the ones to go for
Andrew
Andrew
Demlotcrew and tomson
Sent you both a pm
Sent you both a pm
Thanks tomson for the crossmember, get the car sorted now.
