My question is fairly obvious here so here goes.
Could anyone give me any tips or guidelines to follow before i swap/change it over tomorrow? I have never done one before, is it a job for a pro or would i be ok?
Thank you
Olly
It's only the matrix or heater valve that he wants to change! Only the centre console and glove box panels to come out!wildeian wrote:Quite a bit of work to replace the complete blower unit for a novice. Dash out, open top of bulkhead. Depends if you're feeling brave I suppose
Brianmoooore wrote:It's only the matrix or heater valve that he wants to change! Only the centre console and glove box panels to come out!wildeian wrote:Quite a bit of work to replace the complete blower unit for a novice. Dash out, open top of bulkhead. Depends if you're feeling brave I suppose
It's just that leaking heater valves are common; matrixes not so common.EuRoRiGhTnEsS wrote:dont say that brian, i thought it was only one thing![]()
I couldnt say to be sure, i know its leaking and thats about it![]()
Olly
You might have to remove some of the metalwork for the brake servo bell crank as well to get the matrix out.wildeian wrote:Oh, Ok! Didn't know it would squeeze out of that gap. Always handy to know
