Are all the fuel pumps the same for different engine sizes?
- Brianmoooore
The basic pump is the same, but there are two different mounting brackets. The pump can be changed between brackets if necessary, and just involves soldering two wires.
The difference between the brackets is that some have two pipe connections and others only one.
You can use a two pipe pump in place of a single pipe one by blocking the spare connection with a short piece of fuel hose and a plug of some kind.
If you want to use a single pipe pump in place of a two pipe, then the original bracket must be used and the pump swapped.
gareth
brian, out of curiosity, do you know if a 2 pipe pump be the type fitted to a 318is? i only ask as me, martin (driftboy) and theo (theo325) were a bit puzzled when we found 3 fuel lines on theos 318is when dropping a M30 in the other day. though it seems only one is a pressurised feed and it fired up ok.
sorry for the off topic btw...
- Brianmoooore
Can't remember off hand whats in the iS, but there are three fuel lines on all facelift E30s.
One is the pressurised feed line, one is the fuel tank vent, and the third is the excess fuel return line from the pressure regulator to the tank. This either goes into the tank via a stub pipe on the tank, or by the second connection on the fuel pump.
mull3tt
So if i bought a pump from a 320 for my 318i, i could block 1 of the pipes on the pump and keep it in the car as a spare?Brianmoooore wrote:The basic pump is the same, but there are two different mounting brackets. The pump can be changed between brackets if necessary, and just involves soldering two wires.
- Brianmoooore
correct!mull3tt wrote:So if i bought a pump from a 320 for my 318i, i could block 1 of the pipes on the pump and keep it in the car as a spare?
gareth
so where would the breather connect to? we were thinking into the manifold or something so it sucks up fumes but i've never seen it connected to anything.
- Brianmoooore
Breather pipe does connect to the inlet manifold on emissions equipped cars - via a carbon canister and a solenoid valve.gareth wrote:so where would the breather connect to? we were thinking into the manifold or something so it sucks up fumes but i've never seen it connected to anything.
On most E30s the end just tucks into the reinforcement structure for the LH suspension turret.
gareth
cheers brian!
that's another pint i owe you! well, actually i'll add that to theos tab!
Mystery solved then, there was a bit of head scratching when we were confronted by 3 fuel lines! I've noticed that the engine bay smells of petrol fumes a little, seems odd that it's simply vented to the atmosphere.
Thanks for the info Brain, and cheers for looking into it Gareth.
- Brianmoooore
If you can smell fuel under the bonnet, I very much doubt that it's from the vent pipe.Theo325 wrote: I've noticed that the engine bay smells of petrol fumes a little, seems odd that it's simply vented to the atmosphere.
Far more likely to be a weeping high pressure hose. Check them out ASAP!
- Brianmoooore
This is easily replaced by a single in tank pump as well!Ziggy wrote:Worth mentioning that early cars had a 2-pump setup?
gareth
which will yield a handy spare inline pump for syphoning out fuel etc!Brianmoooore wrote:This is easily replaced by a single in tank pump as well!Ziggy wrote:Worth mentioning that early cars had a 2-pump setup?
