front suspension leg
TheRealest
Mon Mar 19, 2007 12:35 am
is it true that a 325 sport has a shorter suspension leg and if so are the saloon, touring and cab all the same???
ian332isport
Mon Mar 19, 2007 9:12 am
TheRealest wrote:is it true that a 325 sport has a shorter suspension leg and if so are the saloon, touring and cab all the same???
No ,it's not true.
The sport has M-Tech springs which are approx 15mm shorter than standard springs, but the leg itself is the same. There's also a difference in diameter between different models. Some are 45mm, and some are 51mm. It was generally 4 pot cars with the thinner ones and 6 pots with the larger, but I think there was a bit of crossover here and there.
Ian.
