door alignment
The drivers side door on my cab is misaligned...it sits slightly higher when closed and the bottom of the door toes in ie the window/quarter light sit slightly out from the seal at the top corner it also doesn't close cleanly on the striker....is there a specific adjustment to make or is it a case of loosening off the bolts on the hinges and shifting the door around til I'm happy? (the gaps between the panels look reasonably straight)...Cheers
Templ8e30
If the gaps look even then you'll need to add or remove shims from between the hinge and the door, loosen the bolts on 1 hinge and slide out the shims or add as necessary to get the alignment spot-on.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
