battery keeps going flat after three days
jayceexx2000
Sat Feb 10, 2007 6:11 pm
Hi guys i need help ive had my e30 cabby about four moths and it keep flattening the battery.
I have changed the alternator the belt the earth straps the battery everything and i still does it can anyone help
thanks John
kam-325i
Sat Feb 10, 2007 6:23 pm
only other thing is that there is a drain on the battery.
Is there an alarm or immobiliser fitted ?
smithy318i
Sat Feb 10, 2007 6:27 pm
You can find out more in depth info by using the search function, but you should be able to isolate the problem by removing each of the fuses from the fuse box while measuring the drain on the battery.
jayceexx2000
Sat Feb 10, 2007 9:54 pm
yeah it has an immobilisor on it though i'm not sure what type it is at it came with the car
do i need a multimeter to check the battery drain when i remove the fuses?
thanks guys
J
kam-325i
Sat Feb 10, 2007 9:58 pm
yeah, multimeter need'd.
for reference, on my 325i with an immobiliser fitted, current drain with ignition off and boot light off is 0.6A
jayceexx2000
Sat Feb 10, 2007 10:01 pm
cheers buddy i'll check first thing and let you know thanks again j
Sat Feb 10, 2007 10:03 pm
Normal drain is from about 30mA to 90mA, depending on what's fitted. Anything higher needs investigating.
jayceexx2000
Sat Feb 10, 2007 10:05 pm
it has a stereo and the imobilisore apart from that its standard 325i cabby
kam-325i
Sat Feb 10, 2007 10:08 pm
so does mine of 0.6A sound high ?
Sat Feb 10, 2007 10:23 pm
kam-325i wrote:so does mine of 0.6A sound high ?
Misread that in your first post! 0.6A (600ma) is very high. Sure you don't mean 0.06A?
kam-325i
Sat Feb 10, 2007 10:37 pm
Just gone and checked again...you are right Brian, meter flicking between 0.05/6A
