dash removal
seanboy
Fri Jan 19, 2007 11:23 pm
lads how long does it take to remove a dash board and is their a lot in it? cheers
Fri Jan 19, 2007 11:31 pm
A much easier job than it looks. After removing the obvious bits like the centre console, loosening the heater controls panel and unplugging the wiring socket at the back of the glovebox, then there's only four bolts that hold it in, two at each end.
seanboy
Sat Jan 20, 2007 4:09 am
cheers
topi
Sat Jan 20, 2007 3:27 pm
Templ8e30
Sat Jan 20, 2007 4:26 pm
Brianmoooore wrote:A much easier job than it looks. After removing the obvious bits like the centre console, loosening the heater controls panel and unplugging the wiring socket at the back of the glovebox, then there's only four bolts that hold it in, two at each end.
Why do you need to unplug the wiring socket ?, it's attached to the bulkhead not the dash.
Certainly didn't unplug mine when fitting a new dash.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
smithy318i
Sat Jan 20, 2007 5:23 pm
Cheers,
Iain T
I believe Brian is refering to this section of wires. They feed all of the buttons, illumination, and instrument cluster. It terminates at a large rectangular white plug/socket on the underside of the glovebox.
mrLEE30
Sat Jan 20, 2007 5:41 pm
i also removed/unplugged no wires with exception of instrument cluster, job will be easlier with a helper to get the dash back in, keep all the nuts and bolts for each part in seperate plastic ziplock bags., cover your upper steering column in gaffer tape or you may scratch it.
mrlee
bmwe30mtech
Sat Jan 20, 2007 6:05 pm
I found dash removal a pain in the arse and it took me a long time.
To be honest it was one of the first car jobs i did and i didnt know exactly what i was going :?
Sat Jan 20, 2007 9:46 pm
There are two looms that run across the dash from left to right.
One is part of the main body loom, and has to be disconnected from everything it connects to in the dash and remains behind in the car.
The other plugs in at the back left corner of the glovebox and comes out with the dash. Things that connect to it can be left connected.
seanboy
Sun Jan 21, 2007 11:26 am
cheers topi
