lsd oil....?
fuzzy
He who sleeps with "Gingers"
Tue Dec 26, 2006 1:48 pm
im changing the oil in my lsd,the child in halfords says i can use castrol automatic tq dextron 111 transmission fluid. is this correct as it doesnt mention lsd's on it at all? :?
Jimbob
Tue Dec 26, 2006 2:16 pm
Have a look here chap:
http://www.opieoils.co.uk/performance_l ... strol.aspx
There's a BMW specific LSD oil in there :)
Tue Dec 26, 2006 2:19 pm
I'd get it in writing from Halfords before I used it. The evidence will be usefull when you sue them for a new diff.
fuzzy
Tue Dec 26, 2006 2:22 pm
Jimbob wrote:Have a look here chap:
according to this its an automatic gearbox oil for fords,as close as i can expect from halfords really :roll:
SCOTT325SE
Tue Dec 26, 2006 2:27 pm
i just go to BMW stealers and crowbar £50odd quid from my wallet. Just hold ur nose when you fill it, coz the stuff is f**king disgusting!
Jimbob
Tue Dec 26, 2006 2:33 pm
Think my LSD oil from the dealer cost me about £38 quid, just take a spare container with you fuzzy.
SCOTT325SE
Tue Dec 26, 2006 2:34 pm
i think i went overboard with my quantities too. lol.
Jim
Tue Dec 26, 2006 6:45 pm
Just go to your local ford dealer and ask for 2ltrs of lsd oil, about £10 a ltr, stuff they use in the cosworth's, its not auto box oil!
325i Sport
fuzzy
Tue Dec 26, 2006 7:09 pm
Jim wrote:Just go to your local ford dealer and ask for 2ltrs of lsd oil, about £10 a ltr, stuff they use in the cosworth's, its not auto box oil!
is lsd oil all the same ? im using the original bmw lsd.my haynes manual says a drain and refill is 0.9 litres.
Simon
Tue Dec 26, 2006 7:38 pm
I've always used castrol B373, £6 a litre.
Was advised to use this stuff by someone who definitely knows they're stuff when it comes to diffs.
http://peterlloydrallying.co.uk/product ... cts_id=343
fuzzy
Tue Dec 26, 2006 8:11 pm
Simon wrote:I've always used castrol B373, £6 a litre.
thanks 8)
Jim
Tue Dec 26, 2006 10:39 pm
B373 is fine too but has no noise suppression additive with it that is used in lsd's because its designed for off road vehicles (used to sell loads of that to the sunseeker rally team). The e30 lsd holds 1.7ltrs
325i Sport
Dan318-is
Tue Dec 26, 2006 10:40 pm
my bmw stuff was 10 pound from cooper banstead for castrol offiicial smelly stuff cough*gallafant*cough
Tue Dec 26, 2006 10:59 pm
Brianmoooore wrote:I'd get it in writing from Halfords before I used it. The evidence will be usefull when you sue them for a new diff.
:lol:
Agree with Simons choise in Castrol, none of this singing and dancing fully synthetic one'er a gallon stuff was about when these diffs came into practice so why throw your hard earned at unnecessary oils? If you cant bare the £6 a litre, Comma stuff is about £3 per litre!
kevin316i
Wed Dec 27, 2006 1:26 am
The LSD oil from the BMW main dealer is called Castrol SAF-XJ and you will need to bring your own container because they buy it in 25L quantities. It's expensive (about ┚¬25 per litre), but alot cheaper than a LSD!
Small casing diffs take 1L, large casing diffs require almost 2L.
fuzzy
Wed Dec 27, 2006 5:56 pm
kevin316i wrote:The LSD oil from the BMW main dealer is called Castrol SAF-XJ and you will need to bring your own container because they buy it in 25L quantities. It's expensive (about ┚¬25 per litre), but alot cheaper than a LSD!
just bought this from bmw,£17 odds per litre.the oil in the lsd at the moment is green,the new stuff is red :? will they both be lsd oil or is the different colour just down to different manufacturers?
Wed Dec 27, 2006 6:54 pm
Red eh? Just like Dextron III ATF!
