simple 316i front brake upgrade
dtm
Sun Nov 19, 2006 6:18 pm
hi lads,
I need to either renew or upgrade the front brakes on my e30 316i. (they are well corroded after 16yrs)
I was wondering should i just replace the disks and pads (and maybe even calipers) or is there a simple upgrade i can do? (even parts from a newer different car?)
Having chosen either of these options who are the best (cheapest) websites to go to?
Thanks in advance
dtm
ed325i
Sun Nov 19, 2006 6:32 pm
Has your 316 got non vented discs ?
You could fit vented discs and calipers from 325 etc with upgraded pads.
This would be ok to stop a 316.
dtm
Tue Nov 21, 2006 7:10 pm
thanks ed325i for the reply
yes i hvae non vented disks
so new 325i disks and calipers are the way to go?
did all 325i disks and calipers come with the same set up? (for parts reasons)
and would this set up bolt directly onto my front hub assembly?
and where would be my best bet to buy new diskd and calipers?
would my master cylinder be upto pushing out the required amount of fluid?
cheers guys!!
keep up the good work
dtm
ed325i
Tue Nov 21, 2006 8:15 pm
Yes it will just bolt on.
All the discs are the same and there are 2 makes of calipers.
I would get second hand calipers with new discs.
The master cylinder will be ok.
jonbuoy
Tue Nov 21, 2006 8:20 pm
I bought 320i carrier's and caliper's with new disc's and pad's, straight forward bolt on job mate :thumb:
dtm
Thu Nov 23, 2006 1:48 pm
where would be my best bet to buy new disks and new/second hand calipers lads?
also will the 316i brake hoses do?
