325 cutting out (repost)
littlejim
Tue Nov 21, 2006 5:54 pm
Sometimes when I start my 86 325 it runs fine for a minute and then just cuts out,
it just stops, no missfires or spluttering and will not fire up. :cry:
other times it runs fine. :D
fuel pump fuse is ok, I haven't changed the relay yet (there arn't any with the same part no to swap it with in my fuse box)
I tryed bridging the relay connectors when it wouldn't run but still wouldn't fire up.
I thought fuel pumps just stop altogether when they wear out?
I have changed the blue temp sensor and cleaned out the ICV,
changed the plugs, leads, cap and rotor arm,
tested the coil and fly wheel sensors
Richy325iTouring
Tue Nov 21, 2006 5:59 pm
try one of the relays on the n/s wing
littlejim
Tue Nov 21, 2006 6:21 pm
I tryed bridging terminals 30 and 87 on the fuel pump relay but it still wouldn't fire up, it might be flooded I will try again tomorrow.
Richy325iTouring
Tue Nov 21, 2006 6:33 pm
i fixed one yesterday with same problem by changing the white relay
my touring also had the same problem
id put my money on that
