Whistling Stereos
NH325CAB
Wed Nov 08, 2006 1:55 pm
An odd one this....
My stereo has just started whistling/whining in line with the revs and its really annoying.... its quite loud and appears to come from the speakers!?!
I'm even finding myself limiting my speed/revs so that it is in the right key!?!?!?
Anyone got any solutions to get rid of said noise?
Nick
Fushion_Julz
Wed Nov 08, 2006 2:07 pm
probably a poor earth somewhere. If you have an amplifier, check the earth is good on the amp and the head unit and that the resistance between the 2 earth points is 0ohms
then check the interconnect leads if there are any...make sure they are decent quality and the plugs are well soldered.
make sure the signal cables are kept well away from any power cable...If they have to cross, make sure they do so at right angles...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Nov 08, 2006 2:37 pm
ground loop interfearence, it sounds like
r u running amp's etc??
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Nov 08, 2006 2:38 pm
also thi should of really goine in styleing and ice for future ref mate
mark320i
Wed Nov 08, 2006 5:14 pm
if your wires are toutching from head unit to amp running through the car this
will also do it. hapnd to me.
NH325CAB
Wed Nov 08, 2006 7:49 pm
no i dont have an amp or anything... just a head unit and speakers...it just started whistling all of a sudden.
NH325CAB
Thu Nov 09, 2006 12:16 pm
so if i have no amp, any other ideas?
cliffybabe
Powered by Nelly
Powered by Nelly
Thu Nov 09, 2006 12:21 pm
it could be a power cable running near the speakers, r u suing the orignal speaker cable, might be worth upgrading to something a bit better with more shielding
