leaking boot 325i tourer
robbo80
Wed Nov 01, 2006 8:02 pm
Where is it most likely to be coming from .
Wed Nov 01, 2006 8:25 pm
Many places. Narrow it down a bit.
tomtomiS
Wed Nov 01, 2006 10:24 pm
check ur lights first, the gaskets perish over time. theres about 6 8mm nuts which u need to undo and the lens just ejects from the rear. also check that when u fill washer bottle it goes into bottle and not down the outside of the pipe and into ur boot area. while ur at it look at the pipework for rear washwipe and make sure it aint fooked
Chris-W
Thu Nov 02, 2006 8:34 am
The trim panels behind the rearmost side windows is another favourite - they just pop on, and you can get water ingress thruogh the holes.
Morat
Thu Nov 02, 2006 10:21 am
I get a strange "Leak" whenever I try and use the rear wash wipe... is yours working fine?
(if the water is collecting in the LH cubby I'd check it out).
robbo80
Thu Nov 02, 2006 11:07 am
Thaank you guys . rear wiper has seized i think . and rear wash doesent work .
Dan318-is
Thu Nov 02, 2006 11:11 am
i jsut changed my rear light seals (coupe, not touring) as everytime i trained there was a huge puddle of water in the corner of each boot. 8.90 from BMW for two gaskets probably worthwhile maintenance as well
Ziggy
Thu Nov 02, 2006 11:23 am
Dan318-is wrote:everytime i trained there was a huge puddle of water in the corner of each boot
That was just your car crying - I can see why it'd be upset if you'd rather use public transport.
Dan318-is
Thu Nov 02, 2006 11:32 am
so its eyes are at the back. and it cries black water? weird! 8O
Thu Nov 02, 2006 12:14 pm
Morat wrote:I get a strange "Leak" whenever I try and use the rear wash wipe... is yours working fine?
Split washer pipe where it passes through the hinge.
Thu Nov 02, 2006 12:16 pm
robbo80 wrote:Thaank you guys . rear wiper has seized i think .
Unheard of! Rear washer will only work when the rear wiper is travelling in one direction
KDS
Fri Nov 03, 2006 3:54 am
You can also get a leak at the upper corners of the hatch. If you've got an old or poorly fitted gasket, rainwater sliding off the roof of the car can pass between the hatch and the gasket and will eventually pool in your spare tire well or side cubbies.
-KDS in Vancouver ('88 325i Touring)
