325 cutting out
littlejim
Wed Oct 25, 2006 7:20 pm
this morning I started my 325 and it had a miss fire but cleared after reving it up for about 20 seconds but then it just cut out from 2k revs,
It wouldn't restart so I let it sit for a half hour and it started with the same miss fire and it did the same thing, so I let it sit again and the next time I just let it idle but it cut out after 10 second and now it won't start it just turns over.
old_skool
Wed Oct 25, 2006 7:26 pm
What have you checked so far?
littlejim
Wed Oct 25, 2006 7:29 pm
all I've done was charge the battery cause I drained it cranking it over.
old_skool
Wed Oct 25, 2006 7:34 pm
Have you checked fuel, is the fuel pump running? I.e. have you checked the fuel pump fuse and relay and fuel level?
littlejim
Wed Oct 25, 2006 7:41 pm
The gauge shows half a tank I'll have to check the fuse's and relays tomorrow it p*ssing it down at the moment.
jonbuoy
Wed Oct 25, 2006 9:01 pm
Coil pack is a possibility
What has been happening before hand for this to be the end result?
littlejim
Thu Oct 26, 2006 3:59 pm
I checked the fuse, I couldn't find which relay it is in the manual.
It started fine this afternoon, I will have to see if it starts in the morning when its cold and damp.
littlejim
Fri Oct 27, 2006 3:50 pm
It did it again this morning at 7.30, it idled for 10 seconds then cut out and wouldn't fire up it just turns over.
I came home at lunch and it started fine.
