somebody. .PLEASE HELP!!!
mark320i
Sat Oct 21, 2006 7:46 pm
for the last six months ive been doin my engine conversion, took out 2ltr and replaced with a 2.5 running on the old 2.0ltr box, also put a 3:64 lsd on there and rear disc conversion. finally got it all finished today and i was chuffed to bits. drove it round my local area everything seemed fine, then discovered a slight whurring noise? thought nothing of it, doing 60mph plus the back end locked up and i slid down the road, couldnt move it when i had stopped so had to get a mate with a recovery van to tow me home!
the car will only start when the clutch is in, does anyone have any ideas as im well and truly fcuked off lol.
maxfield
Sat Oct 21, 2006 7:48 pm
Something like this happened to be big pimping was the rear diff
mark320i
Sat Oct 21, 2006 7:53 pm
mate it shit me up didnt know what the hell was happenein,
how come i have to put the clutch in for it to start then?
smithy318i
Sat Oct 21, 2006 7:56 pm
gearbox thrust bearing fooked?
TouringMatt
Sat Oct 21, 2006 7:58 pm
Did the van tow you with the rear wheels on the ground?
mark320i
Sat Oct 21, 2006 8:01 pm
no rear wheels had to be lifted as they were
proper locked on.
EThreezero
Sat Oct 21, 2006 8:05 pm
Sounds like the diff's collapsed or summit and its caused :( gearbox damage also making it stick in gear.
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
TouringMatt
Sat Oct 21, 2006 8:08 pm
Sounds like something has locked inside your box maybe?
Pretty sure the reason you cant start the car clutch out is even in neutral there are some gearbox internals spinning, connected via the clutch plate.
old_skool
Sat Oct 21, 2006 8:10 pm
Sounds like the diff's collapsed or summit and its caused gearbox damage also making it stick in gear
Nightmare. I feel for you mate, If it's enough to lock up solid like that then it's terminal. I have got a mate who had this happen on an E30 and it twisted the prop to. Sorry dude. et us know the outcome :(
mark320i
i dont know where to start to be honest?
eko
Old timer
Sat Oct 21, 2006 8:12 pm
unbolt the prop from the diff and see what happens?
old_skool
Sat Oct 21, 2006 8:13 pm
Disconnect the prop from the diff first and then see if the wheels rotate. At least you'll know if the diff is ok and then you can start to logically figure out what's going on. First rule of fault finding in my book is to figure out what isn't wrong and rule it out.
I would suspect something like the input drive on the gearbox, or gearbox internals. Clutch is obviously disengaging for you to be able to start it like you said.
Good luck mate.
TouringMatt
Sat Oct 21, 2006 8:15 pm
Aye, at least you'll know whats fecked then, my moneys on the box.........not nice dude, sounds like you've done some work on it too :(
old_skool
Sorry Eko, we were thinking the same thing at the same time :D
mark320i
Sat Oct 21, 2006 8:16 pm
so if i disconnect the prop then turn the wheels they should spin right?
eko
Old timer
does the clutch pedal and gearstick feel like they should?
old_skool
Sat Oct 21, 2006 8:17 pm
Yes, they should. Just jack up the rear and away you go. (hopefully)
mark320i
yeah clutch seems fine dint check box though
old_skool
Sat Oct 21, 2006 8:18 pm
Look on the bright side. It's likely the gearbox, you've obviously just done tons of work to it so at least you know what's involved in changing the box. You can pick one up for Ԛ£40. Not much help but there is always light at the end of the tunnel 8O
mark320i
Sat Oct 21, 2006 8:46 pm
yeah sumwhere lol, just thought id finally
got it done still really pissed off though, oh well. cheers for the help guys.
old_skool
Sat Oct 21, 2006 8:49 pm
Dont be despondent. After all that work dont give up now :eek:
It'll all be alright in the end.
mark320i
Sat Oct 21, 2006 8:52 pm
its really hard to believe its taken ages to finish
and now sumfin else, gota stay posative or ill go fcuking mental!
Martinaston
Sat Oct 21, 2006 10:51 pm
Pretty sure that would be the gearbox, how many miles on it and did it chatter in neutral before the swap ?
There is NO nucleus.
Sun Oct 22, 2006 1:07 am
Cars can be fun sometimes! I'll go along with the failed gearbox theory.
You had a 2 litre car with a failing gearbox, and now, feeding 2.5 litre power and torque through it has finished it off.
Take three of the bolts out of the front of the prop to confirm its gearbox and not diff.
DRIFTBOY
Sun Oct 22, 2006 1:18 am
Yep.
I had a similar experience in a Capri 2.8i.
90mph, outside lane of motorway, back wheels trying to lock. Nice! 8O
Turned out water had got in the gearbox through a rotten gasket and it seized.
Had some interesting looking gears in there!
mark320i
Sun Oct 22, 2006 10:54 am
i would love to get out there and see what the problem is but
its absolutley pouring down where i am lol, typical!
timbob
Sun Oct 22, 2006 7:48 pm
ahh man, that sucks mark, especially as its taken you so long to get it going!
good luck with it man, hmm, well ill see you in 15 mins anyway lol
323i coupe, silver leather, 18'' lenso RS5's, boge springs, HID's, angels, more to come
wildeian
Mon Oct 23, 2006 3:24 pm
Jack both rear wheels off the ground and start her up - If it starts and they spin => G'box/clutch
mark320i
Thu Oct 26, 2006 5:33 pm
just taken it to the garage and my mechanic seems to think taht it done this cos there was insufficent
oil in the diff. if this is the case is that by diff fcukd or is it repairable?
Thu Oct 26, 2006 6:44 pm
I think your diff is now probably only suitable for use as a large paperweight.
mark320i
Thu Oct 26, 2006 7:33 pm
oh excellent lol
