m20 noisey tappets
dumpydave
Sun Oct 08, 2006 6:58 pm
Hi. I have a 1986 325i which i use for track days.Unfortunatly due to recent events the tappets are becoming a little noisey. Is it an easy job to re-set them? Do i need shims etc? any help would be great. :wink:
telski789
Sun Oct 08, 2006 7:02 pm
its really easy,if you use the search option you'll find a guide on how to do it! Tel
Sun Oct 08, 2006 7:03 pm
Fully adjustable by rotating eccentric discs. All you need are a feeler guage, a 10mm spanner a screwdriver and a short piece of stiff rod (allen key will do) to rotate the discs.
22mm spanner to rotate the engine is usefull as well.
kam-325i
Sun Oct 08, 2006 7:04 pm
dumpydave
Sun Oct 08, 2006 7:30 pm
Thats spot on again chaps thanks. I really must get myself a haynes manual! :mad:
