steering prob fix
i have had stiff steering for about 2 months ant the steering wheel squeeled earpearcingly high pitched as if it was rubbing where it fits on . earlier today i was turning in the road and i felt something slip back into place and my steering is completly fine now . does anyone know what this could be and how to stop it again . cheers
where is the horn ring and if that is the case why did it stop completly when the steering went back to normal. it felt more like a ball joint slipping into place more than a belt slipping , is this possible .
gareth
a dodgy pas pump will make a grating noise that will increase in pitch with engine revs...
- Wookie
- Contact:
Is there any way one can repair a dodgy pump? I've heard you can strip the pump and clean it, but does this work?
There are two types of drivers: Those who dislike BMW drivers, and those who drive BMWs.
gareth
it must be possible but to be honest not really worth it. they're so cheap from a breaker.
