My "is it real or isn't it" 1984 C1 2.3 is going to need some expensive body work.
Last week my other half put my beautiful 1986 525 ETA into a ditch in the snow: so it's now a right off with a well-maintained 80,000 mile engine.
A poke around my turning-green-on-the-drive 318i proves it to be surprisingly sound and dry.
So here's the plan:
1. 525 block and pistons mated to 323 head [lumpy idle and 4000 rpm + power band lead me to suspect a decent cam] = 2.7 clover. 323 manual transmission and [LE Jetronic?] ECU to be retained.
2. 323 alpina running gear, ICE and interior into 318
3. 'new' 2.7 replaces old 1.8.
Questions:
a: The 323 head should fit the ETA lump without fuss, but as the ETA is from an auto, I suspect I'll need a mod for the manual box: will this require a spigot bearing? [What is a spigot bearing???]
b:What mods to the 323's ECU will I need?
c:I beleive the Motronic 525 uses a timing picup on the crank case: how is this taken care of on Jetronic?
d: I dearly love the early 80's dreadnought-style Alpina front valance: can the late model e30 be made to wear this with early style thin bumpers? [Perhaps cheaper to get a later Alpina valance and keep the big bumpers?]
e: The 323 has a standard non-alpina exhaust but it's quite recent: as a stop gap, can the standard 323 exhaust go into the 318?
thanks in advance for any replies
Jon B
