petrol gauge problem...
sicknote
Fri Jun 02, 2006 8:05 pm
does anyone have or had a problem involving the petrol gauge going on them?
mine stays pretty much in the middle but does move as i use petrol
only a little though (i thought i was just getting good mileage :lol: )
when it goes below the half tank mark the red light comes on
are they supposed to do that or is it just not giving me the accurate reading
need to know because i dont know about you lot but i dont fancy stopping in the middle of the m4
ant2
Fri Jun 02, 2006 8:10 pm
ha mine moves from full to empty in about 50 miles, then the light comes on when it is actually empty, its a common problem on these
sicknote
Fri Jun 02, 2006 8:21 pm
so basically, if its reading one thing but the light has come on then it actually is out of fuel?
and thats a common thing?
xedman
Fri Jun 02, 2006 8:37 pm
not an answer to your problem but i share the same problem!!
my half way is empty as well, i go by the OBC to work out whats left
i read somewhere that something under or behind the back seat that goes into the fuel tank needs cleaning
M5pilot
Fri Jun 02, 2006 8:42 pm
Wires to the sender unit may need cleaning or it could be the actual sender unit itself which has the levelling float stuck and wont go below a certain point.
sicknote
Fri Jun 02, 2006 8:43 pm
xedman wrote:not an answer to your problem but i share the same problem!!
sorry mate im a bit slow...
whats an OBC?
if it means the red light then i'll have to judge it on that then.
blingsta
Boost Junkie
Fri Jun 02, 2006 8:48 pm
OBC means on board computer... it shows the range you can cover with amount of fuel in the tank..
xedman
Fri Jun 02, 2006 8:51 pm
you'll have to go by the red light, which will come on when the needle hits half way
ad318i
Fri Jun 02, 2006 10:43 pm
if your red light goes on when the tank says half way there is a problem!!! with both ya cars...
i think you will just need to clean the fuel tank sensors..
brianmoore will be here soon enough and he'll tell ya straight away
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
sicknote
Fri Jun 02, 2006 11:09 pm
nice one people, if the guage actually moves then its not that so it must be a sensor or something then.
looks like the haynes manual will have to come out
unless anyone has any other ideas?
thanks anyway
Sat Jun 03, 2006 9:48 am
Sounds like you have the setup which uses a level sensor in each half of the tank, and one is stuck on full.
Pull one of the sender plugs off and check the gauge goes to zero. Short across each sender plug in turn, and see which one makes no difference to the gauge reading, or just measure their resistance with a meter.
Also, this belongs in tech help!
sicknote
Sun Jun 04, 2006 5:36 pm
apologies...a simple error :)
