Leccy window's playing up
DazzyA
Thu Mar 30, 2006 10:14 pm
Went for a mad thrash on monday night, all windows working ok. Decided we needed the roof down to star gaze and next morning windows wouldn't work unless the passenger door was open. As soon as the interior light plunger thingy was depressed they would'nt work again so have ended up taking the plastic bit off the door so they work.
Any ideas?
Pass me the spanner
DazzyA
Sat Apr 01, 2006 9:32 pm
Help Brian, or anybody.
Pass me the spanner
stonesie
Sun Apr 02, 2006 10:57 am
after a quick rummage i turned this up
http://com4.runboard.com/be30zoneforum.ftechhelp.t4916
hth 8)
DazzyA
Sun Apr 02, 2006 12:54 pm
Thanks stoniesie,
the exact same problem, off to have a look.
cheers again.
Pass me the spanner
DazzyA
Sun Apr 02, 2006 1:05 pm
Blown fuse alright, mine was 25a though.
Pass me the spanner
MONSPORT42
Sun Apr 02, 2006 9:31 pm
Had a similar problem on my Sport. Discovered that the windows circuit is earthed on the starter motor. Cleaned it up and it all works fine.
YOUR LEFT FOOT'S FOR BRAKING
DazzyA
Sun Apr 02, 2006 9:55 pm
I'll give that a clean up too then, cheers.
Pass me the spanner
Sun Apr 02, 2006 11:41 pm
MONSPORT42 wrote:Had a similar problem on my Sport. Discovered that the windows circuit is earthed on the starter motor. Cleaned it up and it all works fine.
Problem here will affect heater fan and mirrors as well.
Sun Apr 02, 2006 11:42 pm
DazzyA wrote:Blown fuse alright, mine was 25a though.
should be 30A.
DazzyA
Mon Apr 03, 2006 5:46 pm
All done, had a 30a lying around so all's well.
Thanks guy's.
Pass me the spanner
Andy325i
Mon Apr 03, 2006 8:59 pm
Sorry to Hi Jack the thread but how do you mean earthed on the starter motor? I have this problem too :(
Andy
Mon Apr 03, 2006 10:23 pm
Andy325i wrote:Sorry to Hi Jack the thread but how do you mean earthed on the starter motor? I have this problem too :(
Andy
He's talking about the unloader relays. 12V+ from ignition on one side of the relays' coils, other terminal of the coils to earth through the low resistance windings of the starter motor.
When the starter is engaged, this "earth" point becomes 12V+, giving no voltage across the relay coils, so they switch off and "unload" the circuits connected to them. (Roof, windows, mirrors, heater fan and seat heaters, if you have them.)
