Clutch problems 325i
Mr_Rossy
Fri Mar 03, 2006 12:05 pm
I got in the car on Tuesday after it had been stood for about 2 months and when I put my foot on the clutch peddle it went to the floor with no resistance. It's not like a snapped cable though.
What could it be ?
Slave ?
Lost fluids ?
Cheers M
Motorhole
Fri Mar 03, 2006 12:36 pm
Check your clutch fluid reservoir! If its empty you got a leak. Find and repair the leak (Slave cylinder normally prime suspect), flush the system and it will be as good as new!
Mr_Rossy
Fri Mar 03, 2006 1:24 pm
Cheers,
Anyone got a picture of where the reservoir is located ?
Bigsidney
Sun Apr 02, 2006 11:18 am
Hi M8 the clutch fluid resivoir is located on the o/s rear of the engine bay next to the windscreen resevoir it is smaller than a coke can about the size of a red bull can with a black cap you can trace it back from the clutch slave cylinder
