I have a weird problem
My RH full beam will not come on
LH is perfect comes on as required, stays on if stalk fwd and flashes if stalk pulled towards me.
Things I have checked
12v to the light when stalk activated
Earth seems good, I have continuity to the chassis
Fuses 1 and 2 checked and swapped across, no difference fault remains on RHS only
Bulb replaced
The only thing common to this circuit is I believe relay K3 ,but obviously LHS operates correctly, unless half of this relay is not working?
All other lights operate correctly.
Any thoughts please it's driving me mad
