I'm currently having my brain bent into shapes that's it's not designed for trying to find the dimensions of the screws for the original roof fitting kit for the BAUR E30 TC2.
I have the roof on and all is good,however it turns out that the screws that are in place are not the original ones and subsequently the Tonnau top will not fit onto the snap on clips because the screws are incorrect.
Originally the roof screws were fitted with this part:
The kit looked like this:
Unfortunatly since the demise of the BMW Classic shop this kit is no longer available and I am currently trying to locate the 3 different types of screws individually.This is tricker than it sounds as the heads of the screws all need to be smaller than 5.7mm in Diameter in order to fit inside the snap-on clip.
If anybody has any information on this it would be greatly appreciated.
