M20 heater return hose connection point
xavier
Sat Jan 09, 2021 2:07 pm
I need to replace the heater return hose. I can see where the front end connects near the thermostat. Where does the other end connect to the heater? Is it a dashboard out job?
Bonymaenjack
Sat Jan 09, 2021 4:36 pm
Look at the engine bay bulkhead near the Fuse box , you should see two pipes one inlet and outlet for the heater , no need to access the heater directly
