I an effort to expand my knowledge a bit beyond the M42, an engine I have spent lots of time living with, I decided to buy an E reg 325i as a bit of a project. Long story short it doesn't run and I'm a tad puzzled. Car is running 35 pin Motronic 1.0 ECU.
- I have fuel at the engine although I want to rig up a gauge and check the pressure in the morning.
- When I removed the plugs they were wet so I therefore assume fuel is getting to the cylinder.
- I checked each spark plug against the rocker and there is spark on all 6.
- The Zone wiki flow chart says to check the blue temp sensor, which on a 3.5degreeC day was reading 4500ohms both at the sensor and the ECU. Seems ok to me...
- I did change the cambelt as there was no history but after triple checking my work, all TDC marks line up and the rotor arm sits on cyl1 of the distributor. As the crank pulley has a keyway it all has to be correct.
- As far as I can tell everything is plugged in and sealed.
Furthermore it has coughed a couple of times like it was going to start, but didn't and continues to crank.
TIA
